Help. How do I resolve this:
SQL Errors in Nagios
Re: SQL Errors in Nagios
Trying to backup the database before running this and getting an error:
Backing up MySQL databases...
mysqldump: Got error: 145: Table './nagios/nagios_servicestatus' is marked as crashed and should be repaired when using LOCK TABLES
Error backing up MySQL database 'nagios' - check the password in this script!Re: SQL Errors in Nagios
You have crashed tables. The backup will not work until the tables are fixed. Run the repair script.
