After my issue after the reboot yesterday, it seems our graphs don't get any data anymore!
tail -25 /usr/local/nagios/var/perfdata.log
2013-11-14 07:00:32 [23456] [0] *** TIMEOUT: Timeout after 5 secs. ***
2013-11-14 07:00:32 [23456] [0] *** TIMEOUT: Deleting current file to avoid NPCD loops
2013-11-14 07:00:32 [23456] [0] *** TIMEOUT: Please check your npcd.cfg
2013-11-14 07:00:32 [23455] [0] *** TIMEOUT: Timeout after 5 secs. ***
2013-11-14 07:00:32 [23459] [0] *** TIMEOUT: Timeout after 5 secs. ***
2013-11-14 07:00:32 [23455] [0] *** TIMEOUT: Deleting current file to avoid NPCD loops
2013-11-14 07:00:32 [23455] [0] *** TIMEOUT: Please check your npcd.cfg
2013-11-14 07:00:32 [23459] [0] *** TIMEOUT: Deleting current file to avoid NPCD loops
2013-11-14 07:00:32 [23459] [0] *** TIMEOUT: Please check your npcd.cfg
2013-11-14 07:00:32 [23456] [0] *** TIMEOUT: /usr/local/nagios/var/spool/perfdata//1384408803.perfdata.service-PID-23456 deleted
2013-11-14 07:00:32 [23456] [0] *** Timeout while processing Host: "hostname" Service: "SRV_Ping"
2013-11-14 07:00:32 [23456] [0] *** process_perfdata.pl terminated on signal ALRM
2013-11-14 07:00:32 [23455] [0] *** TIMEOUT: /usr/local/nagios/var/spool/perfdata//1384408803.perfdata.host-PID-23455 deleted
2013-11-14 07:00:32 [23455] [0] *** Timeout while processing Host: "hostname" Service: "_HOST_"
2013-11-14 07:00:32 [23459] [0] *** TIMEOUT: /usr/local/nagios/var/spool/perfdata//1384408818.perfdata.service-PID-23459 deleted
2013-11-14 07:00:32 [23455] [0] *** process_perfdata.pl terminated on signal ALRM
2013-11-14 07:00:32 [23459] [0] *** Timeout while processing Host: "hostname" Service: "SRV_CPU"
2013-11-14 07:00:32 [23459] [0] *** process_perfdata.pl terminated on signal ALRM
There seems to be no activity after 07:00...
ls /usr/local/nagios/var/spool/checkresults | wc -l
9
ls /usr/local/nagios/var/spool/perfdata | wc -l
5907
ls /usr/local/nagios/var/spool/xidpe | wc -l
0
Any help is welcome!
Already did a restart of npcd
service npcd restart
[root@nagios perfdata]# df -i
Filesystem Inodes IUsed IFree IUse% Mounted on
/dev/mapper/VolGroup00-LogVol00
1286144 111734 1174410 9% /
tmpfs 490139 1 490138 1% /dev/shm
/dev/sda1 25688 39 25649 1% /boot
cifs:/root_vdm_2/cifs402/Backups/SRVNAGIOS01
257949694 3859915 254089779 2% /var/Digipolis/Backup
[root@nagios perfdata]# df -h
20G 7.4G 11G 41% /
tmpfs 1.9G 0 1.9G 0% /dev/shm
/dev/sda1 97M 28M 65M 31% /boot
4.9T 2.9T 2.0T 60% /var/Digipolis/Backup
cat /usr/local/nagios/etc/nagios.cfg | grep check_result
check_result_path=/usr/local/nagios/var/spool/checkresults
max_check_result_reaper_time=30
nano /usr/local/nagios/etc/pnp/process_perfdata.cfg
Changed TIMEOUT to 10 and restarted NPCD service.
Tried to gather as much info as I could find.
Perfdata not working anymore
Nagios XI 5.8.1
https://outsideit.net
Re: Perfdata not working anymore
Ok, I think the problem is (at least partially) solved. In http://support.nagios.com/forum/viewtop ... g&start=10 , so I did a shift - refresh and suddenly I saw data again. it could of course also be the service npcd restart I did a few minutes ago..
'm not quite sure though if everything is working normally again.
When I do tail -25 /usr/local/nagios/var/perfdata.log
There seems to be no new log entries since 07:00 this morning... Or is this considered a good thing?
Also tail -50 /usr/local/nagios/var/npcd.log doesn't seem to get any new logs after I restarted the service.
These are the last logs:
[11-14-2013 10:56:58] NPCD: Caught Termination Signal - Hasta la vista... baby
[11-15-2013 09:25:55] NPCD: npcd Daemon (0.4.14) started with PID=6576
[11-15-2013 09:25:55] NPCD: Please have a look at 'npcd -V' to get license information
[11-15-2013 09:25:55] NPCD: HINT: load_threshold is enabled - ('10.000000')
Omg, what a reboot of a server can cause.... Next time I'll certainly try
instead of
service ndo2db stop
service mysqld stop
service postgresql stop
service nagios stop
shutdown -h nowCode: Select all
shutdown -h nowNagios XI 5.8.1
Having too many files in "/usr/local/nagios/var/spool/perfdata/" directory may indicate that npcd is not running and not processing these files. Make sure the load on the server is not too high (exceeding the load_threshold value, set in the "/usr/local/nagios/etc/pnp/npcd.cfg" file). Also, make sure npcd is set to autostart (after reboot):
chkconfig --list | grep npcdBe sure to check out our Knowledgebase for helpful articles and solutions!
Did not had an issues anymore with npcd since this one, so this thread can be closed. Grtz and tx.
Nagios XI 5.8.1
