Nagiosgraph stepsize
mrninni
Post by mrninni »
I use nagiosgraph 1.4.4.
As reported in the official doc "A typo in 1.4.3 and 1.4.4 prevents the specification of stepsizes, heartbeats, and resolutions. It has been fixed in 1.4.5."
I do not find the versione 1.4.5, but i tried this info:
there is a bug in 1.4.4 that causes nagiosgraph to ignore 'stepsizes' and 'heartbeats'.
in the function 'readconfig' in ngshared.pm (line 805) change:
chomp $key
to:
chop $key
Within my Nagios there are some services checked every 30 secs. This is the current link of the graph (useful to read the hostname, the service and the database).
http://nagios.services/nagiosgraph/cgi- ... mtc_beacon
I'd like to graph the values every 30secs so I changed the following variables
heartbeats = X14-mtc,Beacon_Power_Level,.*=60
stepsizes = X14-mtc,Beacon_Power_Level,.*=30
I deleted the existing RRD file, but it has been created with the default values
rrd_version = "0003"
step = 300
last_update = 1384940553
header_size = 1208
Can anyone help me?
abrist
Red Shirt
Re: Nagiosgraph stepsize
Post by abrist »
As far as I can tell, 1.4.5 was pulled from the usual sources. Nagios does not control that project as it is a third-party community project.
I suggest asking about it on their forums:
http://sourceforge.net/p/nagiosgraph/di ... rce=navbar
mrninni
Post by mrninni »
the following is the Download nagiosgraph page. The last version is 1.4.4
http://sourceforge.net/projects/nagiosg ... giosgraph/
I will post my question in the nagiosgraph forum.
Thanks and regards.
