Fix for livestatus icw nagios 4
I got frustrated about this issue and fixed it the dirty way.
I'm not sure if this 100% works, but I do see the services and hosts in multisite.
git clone git://git.op5.org/nagios/livestatus.git
diff -Naur livestatus/src/TableHosts.cc livestatus.working/src/TableHosts.cc
--- livestatus/src/TableHosts.cc 2013-11-21 16:12:05.138951539 +0100
+++ livestatus.working/src/TableHosts.cc 2013-11-21 16:05:07.185093055 +0100
@@ -256,6 +256,9 @@
table->addColumn(new DownCommColumn(prefix + "comments_with_info",
"A list of all comments of the host with id, author and comment", indirect_offset, false, true));
+ table->addColumn(new DownCommColumn(prefix + "comments_with_extra_info",
+ "A list of all comments of the host with id, author, comment, entry type and entry time", indirect_offset, false, true));
table->addColumn(new CustomVarsColumn(prefix + "custom_variable_names",
"A list of the names of all custom variables", (char *)(&hst.custom_variables) - ref, indirect_offset, CVT_VARNAMES));
table->addColumn(new CustomVarsColumn(prefix + "custom_variable_values",
diff -Naur livestatus/src/TableServices.cc livestatus.working/src/TableServices.cc
--- livestatus/src/TableServices.cc 2013-11-21 16:12:05.138951539 +0100
+++ livestatus.working/src/TableServices.cc 2013-11-21 16:10:27.046093469 +0100
@@ -369,6 +369,9 @@
"A list of all comments of the service with id, author and comment", indirect_offset, false, true));
+ "A list of all comments of the service with id, author, comment, entry type and entry time", indirect_offset, false, true));
if (add_hosts)
g_table_hosts->addColumns(this, "host_", (char *)(&svc.host_ptr) - ref);
@@ -256,6 +256,9 @@
@@ -369,6 +369,9 @@
if (add_hosts)
Re: Fix for livestatus icw nagios 4
Thanks for the feedback!
I also wrote a diff for the 1.2.3i6 version. It's attached.
I tried to clean it up a bit, so all the 2012->2013 stuff is out. It compiles and runs for me.
- patch the tree
- run autoreconf -s;automake --add-missing
- I ran configure with: ./configure CPPFLAGS="-I`pwd`/nagios-400/include/ -I`pwd`/nagios-400"
- patch the tree
livestatus-1.2.3i6_400.diff.txt- patch
- (635.03 KiB) Downloaded 660 times
I think lmiltchev said it best:
lmiltchev wrote:Thanks for the feedback!
Hello,I also wrote a diff for the 1.2.3i6 version. It's attached.
- patch the tree
What do I do with the diff .txt file you attached?
Regards,
Shawn
You need to patch the source with that diff, it has a .txt after it so it could be uploaded here, apologies for the confusion.
For those still who may not be aware, there is an official livestatus version that works with Nagios Core 4 now...
This as opposed to the hacked together versions and patches that have been thrown around...
cd /tmp
wget http://mathias-kettner.com/download/mk-livestatus-1.2.4.tar.gz
tar xzf mk-livestatus-1.2.4.tar.gz
cd mk-livestatus-1.2.4
./configure --with-nagios4
make
make install
I've try but get same result, not success loading module ...scottwilkerson wrote:For those still who may not be aware, there is an official livestatus version that works with Nagios Core 4 now...
This as opposed to the hacked together versions and patches that have been thrown around...Code: Select all
cd /tmp wget http://mathias-kettner.com/download/mk-livestatus-1.2.4.tar.gz tar xzf mk-livestatus-1.2.4.tar.gz cd mk-livestatus-1.2.4 ./configure --with-nagios4 make make install
[1411103342] Nagios 4.0.7 starting... (PID=22761)
[1411103342] Local time is Fri Sep 19 12:09:02 ICT 2014
[1411103342] LOG VERSION: 2.0
[1411103342] qh: Socket '/usr/local/nagios/var/rw/nagios.qh' successfully initialized
[1411103342] qh: core query handler registered
[1411103342] nerd: Channel hostchecks registered successfully
[1411103342] nerd: Channel servicechecks registered successfully
[1411103342] nerd: Channel opathchecks registered successfully
[1411103342] nerd: Fully initialized and ready to rock!
[1411103342] wproc: Successfully registered manager as @wproc with query handler
[1411103342] wproc: Registry request: name=Core Worker 22766;pid=22766
[1411103342] wproc: Registry request: name=Core Worker 22764;pid=22764
[1411103342] wproc: Registry request: name=Core Worker 22765;pid=22765
[1411103342] wproc: Registry request: name=Core Worker 22763;pid=22763
[1411103342] livestatus: Livestatus 1.2.4 by Mathias Kettner. Socket: '/var/lib/nagios/rw/live'
[1411103342] livestatus: Please visit us at http://mathias-kettner.de/
[1411103342] livestatus: Hint: please try out OMD - the Open Monitoring Distribution
[1411103342] livestatus: Please visit OMD at http://omdistro.org
[1411103342] livestatus: Unable to bind adress /var/lib/nagios/rw/live to UNIX socket: No such file or directory
[1411103342] Error: Function nebmodule_init() in module '/usr/local/lib/mk-livestatus/livestatus.o' returned an error. Module will
be unloaded.
[1411103342] Event broker module '/usr/local/lib/mk-livestatus/livestatus.o' deinitialized successfully.
[1411103342] Error: Failed to load module '/usr/local/lib/mk-livestatus/livestatus.o'.
[1411103342] Error: Module loading failed. Aborting.-
@tydt949,
Can you share your nagios.cfg with us please? So we can take a look at your modules?
I think this sub of nagios.cfg is correctly to load livestatus module:slansing wrote:@tydt949,
# EVENT BROKER OPTIONS
# Controls what (if any) data gets sent to the event broker.
# Values: 0 = Broker nothing
# -1 = Broker everything
# <other> = See documentation
broker_module=/usr/local/lib/mk-livestatus/livestatus.o /var/lib/nagios/rw/live
event_broker_options=-1
