can nagios display unknown traps sent to it?
benhank
Post by benhank »
did you know that everything that is impossible is possible?
I just wanted to know if I can have nagios display and report unknown traps sent to it.
Proudly running:
Nagios Network Analyser
Nagios Fusion
sreinhardt
-fno-stack-protector
Re: can nagios display unknown traps sent to it?
Post by sreinhardt »
yes, in the sense that nagios does not interpret the trap, snmptt is what determines if it is known or unknown. There should be a setting in snmptt.ini on exec-ing unknown traps. Setting this to something similar to how other traps are exec-ed in snmptt.conf should do this for you, basically using snmptraphandler.py with some basic arguments. I will say that I have not done this, so it will be a bit of a learning process for us both. I do have a way to test and validate this on my home system once I'm done with my current task. I would note that this may lead to quite a few items in unconfigured objects if not handled carefully.
benhank
Post by benhank »
that was alot of werds. I fell apart after "ye".. JK thanks man I will report my findings.
btw, off the top off your head, have you ever seen this:?
[root@lkennagiost01 ~]# service snmpd restart
Stopping snmpd:                                            [FAILED]
[root@lkennagiost01 ~]# service snmptt restart
Stopping snmptt:                                           [  OK  ]
Starting snmptt: PID file: /var/run/snmptt.pid
                                                           [  OK  ]
[root@lkennagiost01 ~]# service snmptrapd restart
Stopping snmptrapd:                                        [FAILED]
no changed made to the server...
Never mind. I just got medieval on em... wiped them out and replaced them (reinstalled).
Proudly running:
Nagios Fusion
Post by slansing »
Oh.. well then, I guess that is one way to do it, I was going to have you call the init script manually and see if it bails with more verbose output.
benhank
Post by benhank »
yeah but i did a google search, and got a lot of replies saying that there is a bug in the new snmp... so the "screw that!" protocol was invoked.
Proudly running:
Nagios Fusion
Post by slansing »
Hahaha, but what do you mean by the "new snmp?" It may be helpful if you link one of the pages you read.
