PROCS CRITICAL: 686 processes with STATE = RSZDT
costanza2k1
Post by costanza2k1 »
Just got done with my XI install, no hosts or services monitored yet outside of localhost. Any suggestions?
Nagios XI Installation Profile
Download Profile
System:
Nagios XI Version : 2012R2.5
schqnag01 2.6.32-358.23.2.el6.x86_64 x86_64
Red Hat Enterprise Linux Server release 6.5 (Santiago)
Gnome is not installed
Apache Information
PHP Version: 5.3.3
Agent: Mozilla/5.0 (Windows NT 6.1) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/31.0.1650.57 Safari/537.36
Server Name: nagios.vsp.com
Server Address: 10.99.104.4
Server Port: 80
Date/Time
PHP Timezone: America/New_York
PHP Time: Fri, 22 Nov 2013 17:23:52 -0500
System Time: Fri, 22 Nov 2013 17:23:52 -0500
Nagios XI Data
nagios (pid 3319) is running...
NPCD running (pid 1366).
ndo2db (pid 1294) is running...
CPU Load 15: 0.29
Total Hosts: 1
Total Services: 8
Function 'get_base_uri' returns: http://nagios.vsp.com/nagiosxi/
Function 'get_base_url' returns: http://nagios.vsp.com/nagiosxi/
Function 'get_backend_url(internal_call=false)' returns: http://nagios.vsp.com/nagiosxi/includes/components/profile/profile.php
Function 'get_backend_url(internal_call=true)' returns: http://localhost/nagiosxi/backend/
Ping Test localhost
Running:
/bin/ping -c 3 localhost 2>&1
PING localhost.localdomain (127.0.0.1) 56(84) bytes of data.
64 bytes from localhost.localdomain (127.0.0.1): icmp_seq=1 ttl=64 time=0.061 ms
64 bytes from localhost.localdomain (127.0.0.1): icmp_seq=2 ttl=64 time=0.031 ms
64 bytes from localhost.localdomain (127.0.0.1): icmp_seq=3 ttl=64 time=0.030 ms
--- localhost.localdomain ping statistics ---
3 packets transmitted, 3 received, 0% packet loss, time 1999ms
rtt min/avg/max/mdev = 0.030/0.040/0.061/0.016 ms
Test wget To locahost
WGET From URL: http://localhost/nagiosql/index.php
Running:
/usr/bin/wget http://localhost/nagiosql/index.php
--2013-11-22 17:23:54-- http://localhost/nagiosql/index.php
Resolving localhost... ::1, 127.0.0.1
Connecting to localhost|::1|:80... connected.
Length: 5259 (5.1K) [text/html]
Saving to: `/tmp/nagiosql_index.tmp'
0K ..... 100% 459M=0s
2013-11-22 17:23:54 (459 MB/s) - `/tmp/nagiosql_index.tmp' saved [5259/5259]
sreinhardt
-fno-stack-protector
Re: PROCS CRITICAL: 686 processes with STATE = RSZDT
Post by sreinhardt »
Do you have other applications running on this system? It seems to be reporting that you have 686 process running, which as you might guess is quite a few. You might also take a look at running top if you are not sure what might be running so many.
