I am seeing some behavior which does not seem normal to me. Over time I have found Nagios will start over a hundred "/usr/local/nagios/bin/nagios -d /usr/local/nagios/etc/nagios.cfg" and they just sit there until I manually kill them. This consumes a lot of memory and slows my server down. I believe the highest number I have seen is 192 of them. Some are daemons which run and die quickly but others just sit there for days until killed.
Has anyone experienced this or knows what might be causing it?
Thank you.
I'm using Nagios 3.4.1.
Lots of nagios -d processes not doing anything...
sreinhardt
- -fno-stack-protector
Re: Lots of nagios -d processes not doing anything...
Around 3.4.4 there was a patch for duplicating checks (additional processes as nagios forks) when the system has been reloaded. Could this be the case? Is there a reason you have not updated to 3.5.x?
It is possible this is due to that because it seems to get worse when we are doing configuration changes.
No particular reason for not updating yet. Now that 4 is out I might upgrade. Thanks for your response.
sreinhardt
Ya that would make sense, well if you need more details or keep having issues after updating past 3.4.4 let us know!
