Convert attachement bin to txt
vinothsethuram
Post by vinothsethuram »
I'm using $LONGSERVICEOUTPUT$ to get the complete details of the issue.Notification/Alert email is attaching the file in .bin type. Is there any possibility to get the attachment as .txt file or sending the issue details in email body itself without attachment
Regards
Re: Convert attachement bin to txt
That's very odd. Is the .bin file human-readable text?
vinothsethuram
Yes, bin file is human readable in Windows but not in mac os
What attachment are you referring to? Can you PM me the file in question?
vinothsethuram
I'm using $LONGSERVICEOUTPUT$ which attaches the issue details. The attached file type in .bin.
I'm not entirely clear on what's happening here since (as far as I know) Nagios should not be attaching anything in the first place. Can you post the full email notification command you have defined? And can you please PM a copy of the .bin attachment?
vinothsethuram
command_line /usr/bin/printf "%b" "***** Nagios *****\n\nNotification Type: $NOTIFICATIONTYPE$\n\nService: $SERVICEDESC$\nHost: $HOSTALIAS$\nAddress: $HOSTADDRESS$\nState: $SERVICESTATE$\n\nDate/Time: $LONGDATETIME$\n\nAdditional Info:\n\n$LONGSERVICEOUTPUT$\n " | /bin/mail -s "** $NOTIFICATIONTYPE$ Service Alert: $HOSTALIAS$/$SERVICEDESC$ is $SERVICESTATE$ **" $CONTACTEMAIL$
This is the command used to send email. If I use $SERVICEOUTPUT$ then there is no attachment in email ,but getting limited details. If I use $LONGSERVICEOUTPUT$ then email is attaching a bin file which has complete issue details
I tried to PM you, but couldn't attach the bin file
Can you just change the extension to .txt and PM it?
vinothsethuram
Sent PM
Seems to be perfectly readable. Try changing your command to show $SERVICEOUTPUT$ right before the $LONGSERVICEOUTPUT$:
command_line /usr/bin/printf "%b" "***** Nagios *****\n\nNotification Type: $NOTIFICATIONTYPE$\n\nService: $SERVICEDESC$\nHost: $HOSTALIAS$\nAddress: $HOSTADDRESS$\nState: $SERVICESTATE$\n\nDate/Time: $LONGDATETIME$\n\nAdditional Info:\n\n$SERVICEOUTPUT$\n$LONGSERVICEOUTPUT$\n " | /bin/mail -s "** $NOTIFICATIONTYPE$ Service Alert: $HOSTALIAS$/$SERVICEDESC$ is $SERVICESTATE$ **" $CONTACTEMAIL$
