Installing Nagios on Centos 6.4
Hi, I have followed the post on installing Nagios Core from source. It all installs ok with no errors but cannot access the web interface. The processes are all started. Can any one point me in the right direction.
Many thanks
Many thanks
Re: Installing Nagios on Centos 6.4
Are you trying to access the interface locally or remotely? Is there a firewall in place blocking you? What is displayed in the web browser when you try to view the page?
I'm wondering if this is an issue with apache2's virtual host configuration.
I'm having the same problem, but on Ubuntu 13. I have installed from source per instructions found on a google search, and it all appears to be working. However, when I visit the page (http://internalserveraddress/nagios) I get an error saying it's not found on the host. I believe there may be a very fundamental step missing in the configuration of apache's virtual host in the documentation/instructions.
Can anyone help?
Can anyone help?
sreinhardt
- -fno-stack-protector
I would agree, that sounds like apaches vhost setup is not complete, and potentially your permissions on the cgi files that apache would call. Can you provide the guides that you have been using please?
sreinhardt wrote:I would agree, that sounds like apaches vhost setup is not complete, and potentially your permissions on the cgi files that apache would call. Can you provide the guides that you have been using please?
I would like to use something from Nagios, however it is severely outdated. I am using a guide from Ubuntu Geek found at http://www.ubuntugeek.com/how-to-instal ... ander.html. This guide is out of date with the 4.0.2 update because of the service "hack" involved. Still, it would be nice to know how to get the 4.0.1 up and going and learn how to setup proper vhost and permissions through this process.
You can check out the following tutorial, posted on the Nagios Exchange:
http://exchange.nagios.org/directory/Tu ... at/details
After you installed the source, did you install the webconf? If not, change directory to the nagios source directory, and run "make install-webconf":
Then restart httpd:
cd /path/to/nagios/source
make install-webconfCode: Select all
service httpd restartFormer Nagios employee
Completed this install. I've never used CentOS before, but I have accomplished more here than with Ubuntu. However, if I click ANY links other than the "Home" link, I get a "The server encountered an internal error or misconfiguration and was unable to complete your request."lmiltchev wrote:You can check out the following tutorial, posted on the Nagios Exchange:
Any suggestions on where to look from here? By the way, thanks for the help!!!!!
**** EDIT ****
Here are the last few lines from my httpd error_log:
[Mon Dec 02 09:50:01 2013] [error] [client 172.16.0.23] PHP Warning: date(): It is not safe to rely on the system's timezone settings$
[Mon Dec 02 09:50:15 2013] [error] [client 127.0.0.1] Directory index forbidden by Options directive: /var/www/html/
[Mon Dec 02 09:50:19 2013] [error] [client 172.16.0.23] (13)Permission denied: exec of '/usr/local/nagios/sbin/status.cgi' failed, ref$
[Mon Dec 02 09:50:19 2013] [error] [client 172.16.0.23] Premature end of script headers: status.cgi, referer: http://172.16.0.81/nagio$
[Mon Dec 02 09:50:49 2013] [error] [client 172.16.0.23] (13)Permission denied: exec of '/usr/local/nagios/sbin/config.cgi' failed, ref$
[Mon Dec 02 09:50:49 2013] [error] [client 172.16.0.23] Premature end of script headers: config.cgi, referer: http://172.16.0.81/nagio$
[Mon Dec 02 09:50:51 2013] [error] [client 172.16.0.23] PHP Warning: date(): It is not safe to rely on the system's timezone settings$
[Mon Dec 02 09:51:15 2013] [error] [client 127.0.0.1] Directory index forbidden by Options directive: /var/www/html/
[Mon Dec 02 09:51:49 2013] [error] [client 172.16.0.23] (13)Permission denied: exec of '/usr/local/nagios/sbin/tac.cgi' failed, refere$
[Mon Dec 02 09:51:49 2013] [error] [client 172.16.0.23] Premature end of script headers: tac.cgi, referer: http://172.16.0.81/nagios/s$
[Mon Dec 02 09:53:39 2013] [error] [client 172.16.0.23] PHP Warning: date(): It is not safe to rely on the system's timezone settings$
[Mon Dec 02 09:53:43 2013] [error] [client 172.16.0.23] (13)Permission denied: exec of '/usr/local/nagios/sbin/tac.cgi' failed, refere$
[Mon Dec 02 09:53:43 2013] [error] [client 172.16.0.23] Premature end of script headers: tac.cgi, referer: http://172.16.0.81/nagios/s$
[Mon Dec 02 09:53:57 2013] [error] [client 172.16.0.23] (13)Permission denied: exec of '/usr/local/nagios/sbin/tac.cgi' failed
[Mon Dec 02 09:53:57 2013] [error] [client 172.16.0.23] Premature end of script headers: tac.cgi
[Mon Dec 02 09:53:57 2013] [error] [client 172.16.0.23] File does not exist: /var/www/html/favicon.ico, referer: http://172.16.0.81/na$
[Mon Dec 02 09:56:15 2013] [error] [client 127.0.0.1] Directory index forbidden by Options directive: /var/www/html/
[Mon Dec 02 09:56:16 2013] [error] [client 172.16.0.23] PHP Warning: date(): It is not safe to rely on the system's timezone settings$
[Mon Dec 02 09:56:20 2013] [error] [client 172.16.0.23] (13)Permission denied: exec of '/usr/local/nagios/sbin/extinfo.cgi' failed, re$
[Mon Dec 02 09:56:20 2013] [error] [client 172.16.0.23] Premature end of script headers: extinfo.cgi, referer: http://172.16.0.81/nagi$
[Mon Dec 02 10:01:15 2013] [error] [client 127.0.0.1] Directory index forbidden by Options directive: /var/www/html/
Are you running selinux?
If so, disable it with:
And to make the changes persist through reboot:
Edit:
Change:
To:
getenforceCode: Select all
setenforce 0Edit:
/etc/sysconfig/selinuxCode: Select all
SELINUX=enforcingCode: Select all
SELINUX=disabledFormer Nagios employee
That did it!!! I just read it on another forum entry. Thanks,all, for the help!!!
