other than using the email to acknowledge the alerts and add comments,
is there a way to add comments directly in the Nagios web interface other than doing this from the backend?
adding comments
Re: adding comments
Yes, by using the Acknowledge button on your hosts/services. You can also use the notes component:
http://exchange.nagios.org/directory/Ad ... nt/details
Re: adding comments
where is the acknowledge button?
I attached my screen on what I'm seeing
Re: adding comments
or does each host only have 1 comment or acknowledgement available?
Re: adding comments
Click the Advanced tab, then click "See this host in Nagios Core". Then you can enter a comment from this page and it will show up in XI.
Re: adding comments
ah, I found it, that works, thanks!
