graph template - plot negative
zaji_nms
Post by zaji_nms »
Dear Expert,
i need to plot a data source value to negative side on a performance graph template what changes is required to be done ??? i have enclosed attached graph where i can not see the Q traffic and drop pkt due to different unit
Regards,
Yusuf
Zajil NMS
abrist
Red Shirt
Re: graph template - plot negative
Post by abrist »
Can you show us a full output of the check including all 3 performance data metrics?
zaji_nms
Post by zaji_nms »
Performance Data: queued_bw=0.02Mb/s;285.00;342.00; transmitted_bw=0.02Mb/s;285.00;342.00; drop_pkt=356;20;40;
Zajil NMS
sreinhardt
-fno-stack-protector
Post by sreinhardt »
Unless it is expected at some point that you will actually hit the warning and critical numbers, I would highly suggest altering those before looking to change the pnp template. This will make it so that your graph actually has some movement to it, whereas now it would only show a straight line just above 0, similar to what you see now. You might try a warning\critical of 5\10 or 15\30 and see how that works for you. I can fairly safely say that you don't appear to ever go near the current warning and critical values, so this may also provide a little bit more reasonable alerting if something is off.
zaji_nms
Post by zaji_nms »
i only want to plot following value which is drop_pkt=356 negative in graph template , so my ds_1 and ds_2 values will come up and ds_3 will come down
Zajil NMS
zaji_nms
Post by zaji_nms »
solved ...using below command in graph_template
$def[1] .= "CDEF:drop=var3,-1,* " ;
Zajil NMS
