Is there any way to have it ignore case, or should it be, or can I just go home?
2 of XI5.6.14 Prod/DR/DEV - Nagios LogServer 2 Nodes
See my projects on the Exchange at BanditBBS - Also check out my Nagios stuff on my personal page at Bandit's Home and at github
nsti.... or alter the hostname on the remote system to be caps maybe?
I'm with you on the haterade though!
sreinhardt wrote:nsti.... or alter the hostname on the remote system to be caps maybe?
1.) HAHAHAHA, I didn't even see the small case stuff you wrote until I quoted you
2.) I still haven't played around with the newest NSTI Nick linked me to ages ago, just been to darn busy. Plus, it isn't ready for prod environment last I heard, any update on that?
2) There is probably a new version at this point, though not really prod ready. His initial instructions will work, just do a git update to get to the newest version if you already installed it.
PS. Nick suggests that it is *NOT* installed on the XI box.
