Nagios 4.0.2 Error out
cesar.garza
Post by cesar.garza »
Hey guys
just wanna know is there any bugs in the Nagios Core 4.0.2 ? because i just install 4.0.2 and able to pull the nagios page. When i tried to upload some host and services, and restart the nagios, it went smoothly. BUT on the UI, i am not able to see my host and services. I checked the logs and found this and then i google it where i got that there is a bug in the 4.0.2.
[1386085200] wproc:   early_timeout=0; exited_ok=1; wait_status=32512; error_code=0;
[1386085200] wproc:   stderr line 01: /bin/sh: 1: /bin/mail: not found
[1386085200] wproc:   stderr line 02: /usr/bin/printf: write error: Broken pipe
[1386087601] Caught SIGTERM, shutting down...
[1386087601] Successfully shutdown... (PID=6618)
[1386087601] Event broker module 'NERD' deinitialized successfully.
[1386087601] Nagios 4.0.2 starting... (PID=17441)
[1386087601] Local time is Tue Dec 03 16:20:01 UTC 2013
[1386087601] LOG VERSION: 2.0
[1386087601] qh: Socket '/usr/local/nagios/var/rw/nagios.qh' successfully initialized
[1386087601] qh: core query handler registered
[1386087601] nerd: Channel hostchecks registered successfully
[1386087601] nerd: Channel servicechecks registered successfully
[1386087601] nerd: Channel opathchecks registered successfully
[1386087601] nerd: Fully initialized and ready to rock!
[1386087601] wproc: Successfully registered manager as @wproc with query handler
[1386087601] wproc: Registry request: name=Core Worker 17442;pid=17442
[1386087601] wproc: Registry request: name=Core Worker 17445;pid=17445
[1386087601] wproc: Registry request: name=Core Worker 17444;pid=17444
[1386087601] wproc: Registry request: name=Core Worker 17443;pid=17443
[1386087601] Successfully launched command file worker with pid 17446
[1386087979] Caught SIGTERM, shutting down...
[1386087979] Successfully shutdown... (PID=17441)
[1386087979] Event broker module 'NERD' deinitialized successfully.
[1386087979] Nagios 4.0.2 starting... (PID=17607)
[1386087979] Local time is Tue Dec 03 16:26:19 UTC 2013
[1386087979] LOG VERSION: 2.0
[1386087979] qh: Socket '/usr/local/nagios/var/rw/nagios.qh' successfully initialized
[1386087979] qh: core query handler registered
[1386087979] nerd: Channel hostchecks registered successfully
[1386087979] nerd: Channel servicechecks registered successfully
[1386087979] nerd: Channel opathchecks registered successfully
[1386087979] nerd: Fully initialized and ready to rock!
[1386087979] wproc: Successfully registered manager as @wproc with query handler
[1386087979] wproc: Registry request: name=Core Worker 17609;pid=17609
[1386087979] wproc: Registry request: name=Core Worker 17610;pid=17610
[1386087979] wproc: Registry request: name=Core Worker 17611;pid=17611
[1386087979] wproc: Registry request: name=Core Worker 17612;pid=17612
[1386087979] Successfully launched command file worker with pid 17613
[1386088057] EXTERNAL COMMAND: ENABLE_SVC_NOTIFICATIONS;localhost;HTTP
[1386091578] Auto-save of retention data completed successfully.
[1386095178] Auto-save of retention data completed successfully.
[1386098778] Auto-save of retention data completed successfully.
abrist
Red Shirt
Re: Nagios 4.0.2 Error out
Post by abrist »
That log snippet looks fine. What was the issue of concern in this log?
Could you also post the output of:
tail -25 /var/log/httpd/error_log
cesar.garza
this is what i got from my apache2 error.log . This is pretty new server so i have only this amount of log.
[Tue Dec 03 05:57:55 2013] [notice] Apache/2.2.22 (Ubuntu) configured -- resuming normal operations
[Tue Dec 03 05:58:58 2013] [notice] caught SIGTERM, shutting down
[Tue Dec 03 05:59:03 2013] [notice] Apache/2.2.22 (Ubuntu) configured -- resuming normal operations
[Tue Dec 03 05:59:06 2013] [notice] caught SIGTERM, shutting down
[Tue Dec 03 05:59:07 2013] [notice] Apache/2.2.22 (Ubuntu) PHP/5.3.10-1ubuntu3.8 with Suhosin-Patch configured -- resuming normal operations
[Tue Dec 03 06:13:14 2013] [notice] Graceful restart requested, doing restart
[Tue Dec 03 06:13:14 2013] [notice] Apache/2.2.22 (Ubuntu) PHP/5.3.10-1ubuntu3.8 with Suhosin-Patch configured -- resuming normal operations
cesar.garza
Nagios is only showing localhost information right now even though i have added hostgroups and services. I tried ( /usr/local/nagios/bin/nagios -v /usr/local/nagios/etc/nagios.cfg ) and didnt get any errors.
abrist
Red Shirt
Post by abrist »
Could you post that output (of the verify)? You may not have included the new config files in the nagios.cfg.
cesar.garza
root@backup-nagios01:/usr/local/nagios/etc#
root@backup-nagios01:/usr/local/nagios/etc# /usr/local/nagios/bin/nagios -v /usr/local/nagios/etc/nagios.cfg
Nagios Core 4.0.2
Last Modified: 11-25-2013
License: GPL
Reading configuration data...
   Read main config file okay...
Checking objects...
        Checked 242 services.
Warning: Host 'prod-activemq01' has no default contacts or contactgroups defined!
Warning: Host 'prod-activemq02' has no default contacts or contactgroups defined!
Warning: Host 'prod-api-gen01' has no default contacts or contactgroups defined!
Warning: Host 'prod-api-gen02' has no default contacts or contactgroups defined!
Warning: Host 'prod-api-gen03' has no default contacts or contactgroups defined!
Warning: Host 'prod-api-gen04' has no default contacts or contactgroups defined!
Warning: Host 'prod-api-gen05' has no default contacts or contactgroups defined!
Warning: Host 'prod-api-gen06' has no default contacts or contactgroups defined!
Warning: Host 'prod-api01' has no default contacts or contactgroups defined!
Warning: Host 'prod-api02' has no default contacts or contactgroups defined!
Warning: Host 'prod-api03' has no default contacts or contactgroups defined!
Warning: Host 'prod-cass01' has no default contacts or contactgroups defined!
Warning: Host 'prod-cass02' has no default contacts or contactgroups defined!
Warning: Host 'prod-cass03' has no default contacts or contactgroups defined!
Warning: Host 'prod-cass04' has no default contacts or contactgroups defined!
Warning: Host 'prod-cass05' has no default contacts or contactgroups defined!
Warning: Host 'prod-cass06' has no default contacts or contactgroups defined!
Warning: Host 'prod-cass07' has no default contacts or contactgroups defined!
Warning: Host 'prod-cass08' has no default contacts or contactgroups defined!
Warning: Host 'prod-epp01' has no default contacts or contactgroups defined!
Warning: Host 'prod-epp02' has no default contacts or contactgroups defined!
Warning: Host 'prod-epp03' has no default contacts or contactgroups defined!
Warning: Host 'prod-epp04' has no default contacts or contactgroups defined!
Warning: Host 'prod-epp05' has no default contacts or contactgroups defined!
Warning: Host 'prod-graphite01' has no default contacts or contactgroups defined!
Warning: Host 'prod-mysql01' has no default contacts or contactgroups defined!
Warning: Host 'prod-pce01' has no default contacts or contactgroups defined!
Warning: Host 'prod-pce02' has no default contacts or contactgroups defined!
Warning: Host 'prod-pce03' has no default contacts or contactgroups defined!
Warning: Host 'prod-pce04' has no default contacts or contactgroups defined!
Warning: Host 'prod-pce05' has no default contacts or contactgroups defined!
Warning: Host 'prod-redis01' has no default contacts or contactgroups defined!
Warning: Host 'prod-repose01' has no default contacts or contactgroups defined!
Warning: Host 'prod-repose02' has no default contacts or contactgroups defined!
Warning: Host 'prod-sam-iad01' has no default contacts or contactgroups defined!
Warning: Host 'prod-sam-iad02' has no default contacts or contactgroups defined!
Warning: Host 'prod-sam-iad03' has no default contacts or contactgroups defined!
Warning: Host 'prod-sam-iad04' has no default contacts or contactgroups defined!
Warning: Host 'prod-sam-linux01' has no default contacts or contactgroups defined!
Warning: Host 'prod-svc-gen01' has no default contacts or contactgroups defined!
Warning: Host 'prod-svc-gen02' has no default contacts or contactgroups defined!
Warning: Host 'prod-svc-gen03' has no default contacts or contactgroups defined!
Warning: Host 'prod-watchdog-handles' has no default contacts or contactgroups defined!
Warning: Host 'prod-webserver' has no default contacts or contactgroups defined!
        Checked 45 hosts.
        Checked 17 host groups.
        Checked 0 service groups.
        Checked 1 contacts.
        Checked 1 contact groups.
        Checked 67 commands.
        Checked 5 time periods.
        Checked 0 host escalations.
        Checked 45 hosts
        Checked 0 host dependencies
        Checked 5 timeperiods
Checking misc settings...
Total Warnings: 44
Total Errors:   0
nagios.cfg
Nagios.cfg file here
(43.54 KiB) Downloaded 552 times
cesar.garza
I have modified in the nagios.cfg file and seems like its good. But not sure why hosts are not showing on the nagios UI.
abrist
Red Shirt
Post by abrist »
1) Have you set up a new UI user, or are you using the nagiosadmin account?
2) Have you configured any services on these hosts? If not, you may want to configure at the very least a ping check.
cesar.garza
abrist wrote:1) Have you set up a new UI user, or are you using the nagiosadmin account?
I am using nagiosadmin account and i have setup services.cfg and hostgroups.cfg too.
How did you restart nagios service - did you use "stop/start", "restart" or "reload'? You can probably zip up the entire "/usr/local/nagios/etc/" directory and PM it to any of us on the Nagios tech team for a review.
