Nagios repeated notifications with passive checks
bart2puck
Post by bart2puck »
I have a setup where nagios receives a snmp trap from a device. It then notifies the contact defined in config.cfg. that works great. What I am trying to accomplish is have nagios send another notification if the problem isn't acknowledge in a given amount of time. I can not get nagios to send that second notification. I am using external commands to actually make a call as the notification, that all works fine. I don't see nagios attempt to make that second notification.
I cut down all my config files to 1 config file for easy of reading.
#TIMEPERIODS
define timeperiod{
        timeperiod_name 24x7
        alias           24 Hours A Day, 7 Days A Week
        sunday          00:00-24:00
        monday          00:00-24:00
        tuesday         00:00-24:00
        wednesday       00:00-24:00
        thursday        00:00-24:00
        friday          00:00-24:00
        saturday        00:00-24:00
#SERVICES
##handle the trap
        host_name                       serverName
        service_description             TRAP
        is_volatile                     1
        check_command                   check-host-alive
        max_check_attempts              3
        normal_check_interval           1
        retry_check_interval            1
        active_checks_enabled           0
        passive_checks_enabled          1
        notification_interval           1
        notification_options            w,u,c
        notifications_enabled           1
        contact_groups                  admins
#COMMANDS
        command_name    check-host-alive
        command_line    $USER1$/check_ping -H $HOSTADDRESS$ -w 3000.0,80% -c 5000.0,100% -p 5
        command_name  notify-host-by-sip
        command_line /usr/lib64/nagios/plugins/calls/makeCall "$NOTIFICATIONTYPE$"
        command_name notify-service-by-sip
#CONTACT_GROUPS
define contactgroup{
        contactgroup_name       admins
        alias                   Nagios Administrators
        members                 user_sip
#CONTACTS
define contact{
        contact_name  user_sip
        alias  useralias
        service_notification_period  24x7
        host_notification_period  24x7
        service_notification_options  w
        host_notification_options  d
        service_notification_commands notify-service-by-sip
        host_notification_commands  notify-host-by-sip
        email  someNumber@someServer
#HOSTS
        host_name                       localhost
        alias                           Development
        address                         serverIP
        max_check_attempts              5
        alias                           Development
        address                         someIP
Re: Nagios repeated notifications with passive checks
Post by slansing »
I would recommend enabling freshness checking on your passive services, that way, if an update is not received within a given amount of time "say 10 minutes or so" then it will trigger a command to run "usually check_dummy" to change the state to critical and trigger a notification.http://nagios.sourceforge.net/docs/3_0/freshness.html
As far as an acknowledgement? That could be tricky, I don't believe there is really a way to trigger a notification in the case a host/service is not acknowledged, besides running a freshness event handler to trigger a notification after no updates are received.
bart2puck
Post by bart2puck »
thanks slansing. So it is standard to get only 1 notification when an a service changes from non-ok to anything else?
That is correct. One notification/alert when it goes down, if it's down for a week you still get only one, then if it recovers you may get another if you have configured it to alert on recovery.
bart2puck
Post by bart2puck »
hmm. would it be possible using escalations or anything to achieve my goal?
sreinhardt
-fno-stack-protector
Post by sreinhardt »
We should clarify, it is standard to only get one alert at the time of a state change, however the notification interval config option on hosts and services denotes the time frame to send another notification if the host\service is not acknowledged or a check returns it to an ok state. There shouldn't be a need to use escalations unless you want to alter that behavior. Just using notification interval should do it.
bart2puck
Post by bart2puck »
does this apply when a service is using passive checks and not active ones?
abrist
Red Shirt
Post by abrist »
Yes. Problem state passive checks will still re-notify on interval. By default they are treated as hard states, so a passive check that changes the state of an object will not wait for retries and move immediately to notifications (if configured). Like active checks, they will continue to notify on interval until resolved or acknowledged..
bart2puck
Post by bart2puck »
ok. so I see in status.dat this:
	last_notification=1386363433
	next_notification=1386363493
	no_more_notifications=0
	notifications_enabled=1
this tells me there should be another notification 60 seconds later....
but that next notification never happens.
logs show nothing after 1st notification.
here is my lastest config:
#TIMEPERIODS
define timeperiod{
        sunday          00:00-24:00
        monday          00:00-24:00
        tuesday         00:00-24:00
        friday          00:00-24:00
#SERVICES
##handle the trap
        host_name                       localhost
        service_description             TRAPPER
        is_volatile                     0
        check_period                    none
        max_check_attempts              1
#COMMANDS
#CONTACT_GROUPS
        members                 user_sip
#CONTACTS
define contact{
        alias  useralias
        service_notification_options  w,u,c
        email  someNumber@someIP
#HOSTS
        host_name                       localhost
        alias                           Development
        address                         ipAddress
Any thoughts?
sreinhardt
Unless the host also went down at the same time, thus causing the service to stop notifying since it's "parent" host is down, I see no reason that this should not have notified again. I would note that 1 minute notification intervals are probably a little bit quick, for testing maybe set it to 5 min just to be sure its not still executing the previous one. Also which log do you happen to be looking at when you are seeing the first message but not the second?
