check_snmp rate
gborbonus
check_snmp rate
Post by gborbonus »
Can anyone tell me how the rate system is calculating warn, critical or ok state?
I'm using it to check the mail queue status, if a flood comes in (huge change), I'd like to be notified.
So, I have:
/usr/local/nagios/libexec/check_snmp -t 20 -P 3 -L authPriv -a MD5 -x DES -U USERNAME -A PASS -X PASS -H HOST -o .1.3.6.1.4.1.2021.8.1.101.2 --rate -w 15 -c 30
Expected result:
If the mail queue suddenly jumps by 15 or more, warning state and if by 30 or more, critical state. Anything under 15 should be shown as OK.
Result:
Negative numbers, like: -0.0003333333 result in Critical state.
other times -3 will result in OK.
15 or more jump does show warning
Any ideas on what I can do to resolve this?
Re: check_snmp rate
Post by slansing »
This may be what you are running into:
Rate Calculation:
In many places, SNMP returns counters that are only meaningful when
calculating the counter difference since the last check. check_snmp
saves the last state information in a file so that the rate per second
can be calculated. Use the --rate option to save state information.
On the first run, there will be no prior state - this will return with OK.
The state is uniquely determined by the arguments to the plugin, so
changing the arguments will create a new state file.
Are you sure there is not another check that may better serve your needs?
abrist
Red Shirt
Re: check_snmp rate
Post by abrist »
The historical rate numbers should be in:
/usr/local/nagios/var/check_snmp/
Are they there and correct?
Additionally, you may want to set --rate-multiplier:
--rate-multiplier
Converts rate per second. For example, set to 60 to convert to per minute
gborbonus
Re: check_snmp rate
Post by gborbonus »
hi,
I believe this is the best check I can use, unless I make one.
yes, the info is in /usr/local/nagios/var/check_snmp/
If you believe there is a better method to check the change rate, please let me know
abrist
Red Shirt
Re: check_snmp rate
Post by abrist »
What version of check_snmp are you running?
/usr/local/nagios/libexec/check_snmp -V
