Configuring NRPE
wipeout630
Configuring NRPE
I'm running Nagios Core 3.2.3 on Fedora 14 with SELinux disabled. I have installed the NRPE daemon on the remote servers with command rules to match the NRPE plugin rules that are install on the monitoring server. After I write out the rules and create the config files (<machinename.cfg>) in /etc/nagios/servers on the monitoring host, I try service nagios checkconfig and it will not verify. I have checked the log files and can't find anything regarding the nagios config. I have verified file locations are accurate in every nagios config file. When I remove the modifications to the .cfg's nagios verifies. I have attached the .cfg files to my post. All .cfg's are from the monitoring machine. Thank you for your help!
