Check_Oracle_health
Hendrik
Check_Oracle_health
Post by Hendrik »
Hi Guys
Whenever I apply configuration from the core config, my oracle checks fail due to env issues, all env are set for the nagios user, once i go to cli and restart nagios the checks work fine. Where can I add the env to ensure they get set whenever I click the apply configuration button?
tonyyarusso
Re: Check_Oracle_health
Post by tonyyarusso »
The script that runs when you click "Apply Configuration" is /usr/local/nagiosxi/scripts/reconfigure_nagios.sh . I'm not sure I entirely understand your current setup, but if you're saying that it works if you log in to a console as the nagios user and restart the service it work, then perhaps you want to add a sourcing of your profile to that script.
Tony Yarusso
Technical Services
___
TIES
Web: http://ties.k12.mn.us/
Hendrik
Post by Hendrik »
tonyyarusso wrote:The script that runs when you click "Apply Configuration" is /usr/local/nagiosxi/scripts/reconfigure_nagios.sh . I'm not sure I entirely understand your current setup, but if you're saying that it works if you log in to a console as the nagios user and restart the service it work, then perhaps you want to add a sourcing of your profile to that script.
Awesome, exactly what I was looking for.
tonyyarusso
Excellent, you're welcome!
Tony Yarusso
Technical Services
___
TIES
