Solaris 10 Agent
fkroeger
Solaris 10 Agent
Post by fkroeger »
I'm trialling NagiosXI monitoring of some Solaris 10 Sparc servers.
The Solaris Server option inthe Config Wizard (Step 3) shows that a Solaris Agent needs to be installed to monitor the metrics and provides a link to download the Agent Install Instructions : http://assets.nagios.com/downloads/nagi ... _Agent.pdf
Clicking on this link comes up with a "404 Not Found" error.
Can you assist with what I need to install on the Solaris Server please?
Thanks - Fred Kroeger
tonyyarusso
Re: Solaris 10 Agent
Post by tonyyarusso »
Interesting. That agent doesn't actually exist yet - someone must have put the link there in anticipation. The current situation is that you would either need to get NRPE packages from a third-party repository or try to compile it yourself, which we don't have instructions for yet. I'm still in the process of building a better agent for this, but it's not high on the priority list. If you can get NRPE installed successfully we can probably figure out the rest easily enough.
Tony Yarusso
Technical Services
___
TIES
Web: http://ties.k12.mn.us/
