Different kind of "Timed out"
sholdings
Post by sholdings »
Dear Sir,
I found there are 4 different "Timed out" messages.
What are the difference among them? What cause they happened?
_ Service Check Timed Out
_ Plugin timed out after 10 seconds
_ Command timed out after 60 seconds
mguthrie
Re: Different kind of "Timed out"
Post by mguthrie »
Can you give a little more insight as to where you're seeing these and what you need to know about them?
sholdings
Post by sholdings »
From XI console, when you check service status it show up on "status information" column. It is on nagios.log and status.dat too.
Need to know, why those message was generated? problem is on agent, nagio core, plugin or ....
mguthrie
Post by mguthrie »
If you can post the actual log entries, status.dat line, and the "status information", where you're seeing this, I'll be able to do a much better job answering your question. Time outs can happen for a variety of reasons, so I couldn't tell you off the top of my head why each of those are there.
