login page won't be load :((
sum2008
Post by sum2008 »
hi
i install nagiosxi on cent os,and the first time i could login to the web interface of nagios
but, now it show just the welcome page, and then, when i click on a "access nagios xi" link, it show nothing(white page)....
another one, i download the vmware image of nagiosxi,and run it , but it has the same problem...:(((
i search very very much,but nothing special ....
please help me as soon as possible,i dont have time to try and error solutions:((
tnx all
Re: login page won't be load :((
Run the following three commands and show us the output:
tail -25 /var/log/httpd/error_log
iptables -L -n
sestatus
sum2008
Post by sum2008 »
[root@localhost ~]# tail -25 /var/log/httpd/error_log
[Mon Dec 09 15:56:41 2013] [error] [client 192.168.88.2] PHP Warning: mysql_pconnect(): Can't connect to local MySQL server through socket '/var/lib/mysql/mysql.sock' (111) in /usr/local/nagiosxi/html/db/adodb/drivers/adodb-mysql.inc.php on line 383, referer: http://192.168.88.2/
[Mon Dec 09 16:51:23 2013] [error] [client 127.0.0.1] PHP Warning: date(): It is not safe to rely on the system's timezone settings. You are *required* to use the date.timezone setting or the date_default_timezone_set() function. In case you used any of those methods and you are still getting this warning, you most likely misspelled the timezone identifier. We selected 'Asia/Tehran' for 'IRST/3.0/no DST' instead in /var/www/html/index.php on line 84
[Mon Dec 09 16:51:23 2013] [error] [client 127.0.0.1] PHP Warning: date(): It is not safe to rely on the system's timezone settings. You are *required* to use the date.timezone setting or the date_default_timezone_set() function. In case you used any of those methods and you are still getting this warning, you most likely misspelled the timezone identifier. We selected 'Asia/Tehran' for 'IRST/3.0/no DST' instead in /var/www/html/index.php on line 106
the firewall and selinux are disable
sum2008
Post by sum2008 »
anyone can help me please?
abrist
Red Shirt
Post by abrist »
It looks like mysql is not running or the credentials are wrong. Was mysql pre-installed on this server or did you use a minimal install?
Lets try to start mysql:
service mysqld status
service mysqld start
sum2008
Post by sum2008 »
hi
tnx
that was correct, the mysql was stoped...
i fixed it with these commands:
root@ns1:/root#
rm -rf /var/lib/mysql/mysql.sock
root@ns1:/root#
service mysqld restart
Stopping mysqld: [ OK ]
Starting mysqld: [ OK ]
root@ns1:/root#
abrist
Red Shirt
Post by abrist »
There must have been an unclean shutdown of the box or mysqld service if the socket still existed when it was stopped. Is the login working now?
