Nagios command expansion
vinothsethuram
Post by vinothsethuram »
Please find attached screenshot. Command expansion option is always showing two times for both host and services. Does it mean that two nagios instance are running
command_expansion
command_expansion
Re: Nagios command expansion
No, this is a normal output.
Post by slansing »
It appears as though your macros should be dynamically filled with this feature, however, it does not appear to be working correctly. We will do a bit of digging, but this may have to be pushed to a bug tracker ticket:
tracker.nagios.org
