NRPE says "Host not allowed to talk to us"
kevinlong206
Post by kevinlong206 »
I am having NRPE communication issues on my ubuntu VMs (debian machines are fine, same subnet and nrpe.conf file). The syslog on the nrpe machine is saying the IP is not allowed, but it should be allowed from the .conf file.
arrow@nagios:~$ /usr/lib/nagios/plugins/check_nrpe -H 10.20.10.158 -c check_all_disks
CHECK_NRPE: Error - Could not complete SSL handshake.
On the *client* machine running NRPE daemon (syslog)
Dec 12 18:13:10 monitor-01 nrpe[9095]: Connection from 10.20.11.38 port 9617
Dec 12 18:13:10 monitor-01 nrpe[9095]: Host 10.20.11.38 is not allowed to talk to us!
Dec 12 18:13:10 monitor-01 nrpe[9095]: Connection from 10.20.11.38 closed.
But that IP is indeed in the allowed_hosts file (the /24 of that subnet), and I have killed / restarted NRPE ( and even rebooted the server!) Also, this *is* the right path to the conf file, as verified by ps aux | grep nrpe .
# cat /etc/nagios/nrpe.cfg | grep allowed_hosts
allowed_hosts=10.20.11.0/24,127.0.0.1
The only other strange this is some error messages related to open-vm-tools , which I hope are not related but could be, this message is repeating every 30 seconds:
Dec 12 18:08:42 monitor-01 vmsvc[1153]: [ warning] [guestinfo] Failed to get nic info.
abrist
Red Shirt
Re: NRPE says "Host not allowed to talk to us"
Post by abrist »
kevinlong206 wrote:But that IP is indeed in the allowed_hosts file (the /24 of that subnet), and I have killed / restarted NRPE ( and even rebooted the server!) Also, this *is* the right path to the conf file, as verified by ps aux | grep nrpe .
It may be the right path, depending on your installation method:
1) From a repo - many distros install nagios/nrpe configs to /etc/nagios. If you installed from a repo this is the right path usually.
2) From source - our source installer installs to /usr/local/nagios/etc. If you installed nrpe from source, your nrpe.cfg should be here.
Additionally, do you start nrpe through xinetd or as a standalone daemon?
kevinlong206
abrist wrote: It may be the right path, depending on your installation method:
Thanks Abrist - I was sure it was the right path because I can see in the ps aux|grep nrpe output, the -c /etc/nagios/nrpe.cfg argument is in the commandline of the running process.
I resolved the issue by installing nrpe v 2.14 from source, the package that was uninstalled previously was 2.12 in the Version: 2.12-4ubuntu3 package.
Regards,
Kevin
So is your issue fully resolved?
