Can NagiosXI monitor Domino - email server and IPCOP - proxy linux server
THANK YOU!!!
Monitoring
Re: Monitoring
Have a look here for Domino:
http://exchange.nagios.org/directory/Pl ... tus-Domino
And here for IPCOP:
http://exchange.nagios.org/index.php?op ... word=ipcop
And here for IPCOP:
Configuration:
Nagios XI 2014R2.5
manually upgraded on 64bits CentOS 6
with nothing extra, no gnome, no proxy, no SSL
Add-ons: Hypermap, Minemap, Ping Action, Traceroute Action, Network Replay, Graph Explorer, Latest Alert
Nagios XI 2014R2.5
Re: Monitoring
Right on! Thanks for posting the information srrhd.
Nicholas Scott
Re: Monitoring
You're welcome !
I am now moving to Customers' Forum, see you there.
Configuration:
Nagios XI 2014R2.5
Nagios XI 2014R2.5
deepeshkumargopal
Re: Monitoring
we have installed nagios monitoring tool in our server and the total process output from nagios screen is showing a different value than the current process numbers from top command. Can any one helpo me on this
The output i am getting is PROCS oK 25 processes state RSZDT..
when we isssue top command the total number of procs is more than 225.
We have decided a threshold of 300 for warning and 450 for critical..
Please help on this..
regards,
Deepesh
regards,
Deepesh
Re: Monitoring
What does the command definition look like for that particular check? It's possible there's a filtering option for that check that's returning a lower number of processes. Here's the plugin doc:
Checks all processes and generates WARNING or CRITICAL states if the specified
metric is outside the required threshold ranges. The metric defaults to number
of processes. Search filters can be applied to limit the processes to check.
./check_procs -h
Usage: check_procs -w <range> -c <range> [-m metric] [-s state] [-p ppid]
[-u user] [-r rss] [-z vsz] [-P %cpu] [-a argument-array]
[-C command] [-t timeout] [-v]
Options:
-h, --help
Print detailed help screen
-V, --version
Print version information
-w, --warning=RANGE
Generate warning state if metric is outside this range
-c, --critical=RANGE
Generate critical state if metric is outside this range
-m, --metric=TYPE
Check thresholds against metric. Valid types:
PROCS - number of processes (default)
VSZ - virtual memory size
RSS - resident set memory size
CPU - percentage cpu
ELAPSED - time elapsed in seconds
-t, --timeout=INTEGER
Seconds before connection times out (default: 10)
-v, --verbose
Extra information. Up to 3 verbosity levels
Filters:
-s, --state=STATUSFLAGS
Only scan for processes that have, in the output of `ps`, one or
more of the status flags you specify (for example R, Z, S, RS,
RSZDT, plus others based on the output of your 'ps' command).
-p, --ppid=PPID
Only scan for children of the parent process ID indicated.
-z, --vsz=VSZ
Only scan for processes with vsz higher than indicated.
-r, --rss=RSS
Only scan for processes with rss higher than indicated.
-P, --pcpu=PCPU
Only scan for processes with pcpu higher than indicated.
-u, --user=USER
Only scan for processes with user name or ID indicated.
-a, --argument-array=STRING
Only scan for processes with args that contain STRING.
--ereg-argument-array=STRING
Only scan for processes with args that contain the regex STRING.
-C, --command=COMMAND
Only scan for exact matches of COMMAND (without path).
RANGEs are specified 'min:max' or 'min:' or ':max' (or 'max'). If
specified 'max:min', a warning status will be generated if the
count is inside the specified range
This plugin checks the number of currently running processes and
generates WARNING or CRITICAL states if the process count is outside
the specified threshold ranges. The process count can be filtered by
process owner, parent process PID, current state (e.g., 'Z'), or may
be the total number of running processes
Examples:
check_procs -w 2:2 -c 2:1024 -C portsentry
Warning if not two processes with command name portsentry.
Critical if < 2 or > 1024 processes
check_procs -w 10 -a '/usr/local/bin/perl' -u root
Warning alert if > 10 processes with command arguments containing
'/usr/local/bin/perl' and owned by root
check_procs -w 50000 -c 100000 --metric=VSZ
Alert if vsz of any processes over 50K or 100K
check_procs -w 10 -c 20 --metric=CPU
Alert if cpu of any processes over 10%% or 20%%Re: Monitoring
Thank you very much!
After I downloaded and installed the plugins for IPCOP and Domino, how will I able to monitor it? What are the steps.
tonyyarusso
Re: Monitoring
Have a look at the documentation and training video.
