I can't find the solutin that the error "connection could not be established within 60 seconds"
I'm using nagios 4.0.2 on CentOS 6.4.
I got the error message from November 11th.
Some host shows State: CRITICAL, but others are State:OK.
I didn't change the setting.
What should I do the matter?
my sql connection could not be established within
Kanako Shinkura
Re: my sql connection could not be established within
Is this a mysql check? Could you post the full service check and command?
