2009R1.4B installation failing at E-importnagiosql
TSCAdmin
Post by TSCAdmin »
I am trying to install 2009R1.4B on CentOS 5.6 64 bit. I ran the script sequentially and everything seemed to work fine except E-importnagiosql.
The error is:
Error: Cannot open config file '/usr/local/nagios/etc/contacttemplates.cfg' for reading: No such file or directory
The complete output of the script is as follows:
# ./E-importnagiosql
NOTE: If prompted, enter the MySQL root password
NagiosQL database appears OK - continuing...
NDOUtils database appears OK - continuing...
Found config files to import - continuing...
/tmp/nagiosxi/nagiosxi/basedir/scripts /tmp/nagiosxi
CMDLINE
/usr/bin/wget --save-cookies nagiosql.cookies --keep-session-cookies http://localhost/nagiosql/index.php --no-check-certificate --post-data 'Submit=Login&tfUsername=nagiosxi&tfPassword=n@gweb' -O nagiosql.login--2011-05-26 02:48:12--  http://localhost/nagiosql/index.php
Resolving localhost... 127.0.0.1
Connecting to localhost|127.0.0.1|:80... connected.
Length: 0 [text/html]
Saving to: `nagiosql.login'
    [ <=>        ] 0           --.-K/s   in 0s
2011-05-26 02:48:12 (0.00 B/s) - `nagiosql.login' saved [0/0]
IMPORTING CONFIG FILES...Array
    [0] => commands.cfg
    [1] => contacts.cfg
    [2] => localhost.cfg
    [3] => nagiosadmin.cfg
    [4] => templates.cfg
    [5] => timeperiods.cfg
    [6] => xicommands.cfg
    [7] => xiobjects.cfg
    [8] => xitemplates.cfg
    [9] => xiwzardtemplates.cfg
IMPORTING /usr/local/nagios/etc/import/commands.cfg
CMDLINE:
/usr/bin/wget --load-cookies=nagiosql.cookies http://localhost/nagiosql/admin/import.php --no-check-certificate --post-data 'chbOverwrite=1&selImportFile[]=/usr/local/nagios/etc/import/commands.cfg' -O nagiosql.import.monitoring
--2011-05-26 02:48:12--  http://localhost/nagiosql/admin/import.php
Saving to: `nagiosql.import.monitoring'
2011-05-26 02:48:12 (0.00 B/s) - `nagiosql.import.monitoring' saved [0/0]
IMPORTING /usr/local/nagios/etc/import/contacts.cfg
CMDLINE:
/usr/bin/wget --load-cookies=nagiosql.cookies http://localhost/nagiosql/admin/import.php --no-check-certificate --post-data 'chbOverwrite=1&selImportFile[]=/usr/local/nagios/etc/import/contacts.cfg' -O nagiosql.import.monitoring
IMPORTING /usr/local/nagios/etc/import/localhost.cfg
CMDLINE:
/usr/bin/wget --load-cookies=nagiosql.cookies http://localhost/nagiosql/admin/import.php --no-check-certificate --post-data 'chbOverwrite=1&selImportFile[]=/usr/local/nagios/etc/import/localhost.cfg' -O nagiosql.import.monitoring
IMPORTING /usr/local/nagios/etc/import/nagiosadmin.cfg
CMDLINE:
/usr/bin/wget --load-cookies=nagiosql.cookies http://localhost/nagiosql/admin/import.php --no-check-certificate --post-data 'chbOverwrite=1&selImportFile[]=/usr/local/nagios/etc/import/nagiosadmin.cfg' -O nagiosql.import.monitoring
IMPORTING /usr/local/nagios/etc/import/templates.cfg
CMDLINE:
/usr/bin/wget --load-cookies=nagiosql.cookies http://localhost/nagiosql/admin/import.php --no-check-certificate --post-data 'chbOverwrite=1&selImportFile[]=/usr/local/nagios/etc/import/templates.cfg' -O nagiosql.import.monitoring
IMPORTING /usr/local/nagios/etc/import/timeperiods.cfg
CMDLINE:
/usr/bin/wget --load-cookies=nagiosql.cookies http://localhost/nagiosql/admin/import.php --no-check-certificate --post-data 'chbOverwrite=1&selImportFile[]=/usr/local/nagios/etc/import/timeperiods.cfg' -O nagiosql.import.monitoring
IMPORTING /usr/local/nagios/etc/import/xicommands.cfg
CMDLINE:
/usr/bin/wget --load-cookies=nagiosql.cookies http://localhost/nagiosql/admin/import.php --no-check-certificate --post-data 'chbOverwrite=1&selImportFile[]=/usr/local/nagios/etc/import/xicommands.cfg' -O nagiosql.import.monitoring
IMPORTING /usr/local/nagios/etc/import/xiobjects.cfg
CMDLINE:
/usr/bin/wget --load-cookies=nagiosql.cookies http://localhost/nagiosql/admin/import.php --no-check-certificate --post-data 'chbOverwrite=1&selImportFile[]=/usr/local/nagios/etc/import/xiobjects.cfg' -O nagiosql.import.monitoring
IMPORTING /usr/local/nagios/etc/import/xitemplates.cfg
CMDLINE:
/usr/bin/wget --load-cookies=nagiosql.cookies http://localhost/nagiosql/admin/import.php --no-check-certificate --post-data 'chbOverwrite=1&selImportFile[]=/usr/local/nagios/etc/import/xitemplates.cfg' -O nagiosql.import.monitoring
IMPORTING /usr/local/nagios/etc/import/xiwzardtemplates.cfg
CMDLINE:
/usr/bin/wget --load-cookies=nagiosql.cookies http://localhost/nagiosql/admin/import.php --no-check-certificate --post-data 'chbOverwrite=1&selImportFile[]=/usr/local/nagios/etc/import/xiwzardtemplates.cfg' -O nagiosql.import.monitoring
SETUID ROOT OK
RESETTING PERMS
CMDLINE
/usr/bin/wget --save-cookies nagiosql.cookies --keep-session-cookies http://localhost/nagiosql/index.php --no-check-certificate --post-data 'Submit=Login&tfUsername=nagiosxi&tfPassword=n@gweb' -O nagiosql.login--2011-05-26 02:48:13--  http://localhost/nagiosql/index.php
2011-05-26 02:48:13 (0.00 B/s) - `nagiosql.login' saved [0/0]
CMDLINE:
/usr/bin/wget --load-cookies=nagiosql.cookies http://localhost/nagiosql/admin/verify.php --no-check-certificate --post-data 'writeMonitoring=Go' -O nagiosql.export.monitoring
--2011-05-26 02:48:13--  http://localhost/nagiosql/admin/verify.php
Saving to: `nagiosql.export.monitoring'
2011-05-26 02:48:13 (0.00 B/s) - `nagiosql.export.monitoring' saved [0/0]
Saving to: `nagiosql.export.additional'
2011-05-26 02:48:13 (0.00 B/s) - `nagiosql.export.additional' saved [0/0]
CMDLINE:
/usr/bin/wget --load-cookies=nagiosql.cookies http://localhost/nagiosql/admin/verify.php --no-check-certificate --post-data 'writeAdditional=Go' -O nagiosql.export.additional
OUTPUT:
Nagios Core 3.2.3
Copyright (c) 2009-2010 Nagios Core Development Team and Community Contributors
Last Modified: 10-03-2010
License: GPL
Reading configuration data...
   Read main config file okay...
Processing object config directory '/usr/local/nagios/etc/static'...
Processing object config file '/usr/local/nagios/etc/static/xiobjects.cfg'...
Processing object config file '/usr/local/nagios/etc/static/xitemplates.cfg'...
Processing object config file '/usr/local/nagios/etc/static/xitest.cfg'...
Processing object config file '/usr/local/nagios/etc/contacttemplates.cfg'...
     directives and data defintions.  If you are upgrading from a previous
     may have been removed or modified in this version.  Make sure to read
RET: 254
/usr/local/nagiosxi/nom/checkpoints/nagioscore/errors /tmp/nagiosxi/nagiosxi/basedir/scripts
tar: Removing leading `/' from member names
ls: /usr/local/nagiosxi/nom/checkpoints/nagioscore/*.gz: No such file or directory
NO NOM SNAPSHOT FOUND!
/tmp/nagiosxi
ERROR: NagiosQL import appears to have failed - exiting.  (Reason: Nagios Core configuration is invalid)
Is there something I am missing?
nscott
Re: 2009R1.4B installation failing at E-importnagiosql
Post by nscott »
TSCAdmin,
It looks as if the templates are not being created properly. This could be from a couple places during the install.
Could you run the the ./fullinstall from the nagiosxi directory, dumping the entire output of the ./fullinstall to some text file and emailing the text file to [email protected]? I just tried installing this on CentOS 5.6 64-bit box to ensure no compatibility issues, and that doesn't seem to be the problem.
Also, just out curiosity, why are you installing 2009?
Nicholas Scott
TSCAdmin
Post by TSCAdmin »
nscott wrote:TSCAdmin,
I have just e-mailed the output of fullinstall to [email protected]
We are running Nagios XI 2009R1.3 on our production server and intend to import files from it to the dev environment. I am unsure whether 2011R1.3 is backward compatible with 2009. Do you have any suggestions?
admin
Site Admin
Post by admin »
It looks like the following file doesn't exist:
You might want to run the following script to make sure the permissions on the /usr/local/nagios/etc directory are correct:
/usr/local/nagiosxi/scripts/reset_config_perms.sh
Ethan Galstad
President
TSCAdmin
Post by TSCAdmin »
I was wondering if I install 2011 would it be:
1. able to understand the configuration files from 2009? I intend to do backup files from 2009 and import on 2011 install.
2. support license keys generated for 2009?
tonyyarusso
Post by tonyyarusso »
TSCAdmin wrote:1. able to understand the configuration files from 2009? I intend to do backup files from 2009 and import on 2011 install.
Yes.
TSCAdmin wrote:2. support license keys generated for 2009?
I believe it uses the same actual key, but you have to do an extra activation process for it.
Tony Yarusso
Technical Services
___
TIES
Web: http://ties.k12.mn.us/
TSCAdmin
Post by TSCAdmin »
Sounds great. I will try it and give you a shout if I am stuck. Thanks
nscott
Post by nscott »
Alright, hope all goes well!
Nicholas Scott
TSCAdmin
Post by TSCAdmin »
I think I have cracked it!!!
I am actually behind a proxy server that could not be bypassed. I understand that Nagios XI installation is not supported behind proxy server but in some cases you have no choice.
After reading the scripts, here is what I think can work for almost everyone as it did for me
1. Before running any installation script install php-pear package manually
2. Set proxy for PHP Pear
pear config-set http_proxy 'http://example.com:8080'
3. Run Nagios installation scripts sequentially
4. Unset system proxy before running E-importnagiosql script
Thank you Nagios support team and especially Mike Guthrie. Cheers :)
mguthrie
Post by mguthrie »
Thanks for the feedback! I posted your steps to our wiki on proxy installs:
http://support.nagios.com/wiki/index.ph ... th_Proxies
