It seems that importing service escalations doesn't work very well.
I have followed the import prep steps for the service escalations and only one service escalation is imported per host.
Any ideas?
Importing Service Escalations
griffithusg
Re: Importing Service Escalations
Looking at my file and what escalations do end up being imported.
I have noticed that it is always the last service escalation in the config file associated with the host. It maybe that the script is overwriting them all.
I can see that it thinks it is importing more than what is shown in the CCM.
I can also confim that the DB only has the records showing for the couple that are shown in the CCM.
I think the import script might not like escalations
I'll put this on our tracker as an issue to investigate. Thanks for the report!
http://tracker.nagios.com/view.php?id=152
Ethan Galstad
President
Ethan Galstad
President
