Bandwidth Usage Report graph in bits/s instead of bytes/s
CedricD
Post by CedricD »
Is it possible to get a graph like this in bits/sec instead of bytes/second?
Thanks.
Re: Bandwidth Usage Report graph in bits/s instead of bytes/
Post by slansing »
It depends, does the plugin you are using support checking bits/s instead of bytes/s?
