Nagios 4.0.2 not reloading config on restart through .cmd
Conz
Post by Conz »
I just installed a new server to host our Nagios 4.0.2 with CentOS 6.5.
It is set up with nagiosQL to manage all the config files. when giving a restart command through nagiosql, nagios will restart but it will not re-load the config files it seems.
It will keep monitoring monitored hosts and services till I give a service restart command from the server shell.
There are no errors that I can see and the only difference with a restart from the console is that it actually kills the processes.
Anyone any ideas ?
[17-12-2013 11:52:15] wproc: Registry request: name=Core Worker 16020;pid=16020
Informational Message[17-12-2013 11:52:15] wproc: Registry request: name=Core Worker 16023;pid=16023
Informational Message[17-12-2013 11:52:15] wproc: Registry request: name=Core Worker 16022;pid=16022
Informational Message[17-12-2013 11:52:15] wproc: Registry request: name=Core Worker 16021;pid=16021
Informational Message[17-12-2013 11:52:15] wproc: Successfully registered manager as @wproc with query handler
Informational Message[17-12-2013 11:52:15] nerd: Fully initialized and ready to rock!
Informational Message[17-12-2013 11:52:15] nerd: Channel opathchecks registered successfully
Informational Message[17-12-2013 11:52:15] nerd: Channel servicechecks registered successfully
Informational Message[17-12-2013 11:52:15] nerd: Channel hostchecks registered successfully
Informational Message[17-12-2013 11:52:15] qh: core query handler registered
Informational Message[17-12-2013 11:52:15] qh: Socket '/usr/local/nagios/var/rw/nagios.qh' successfully initialized
Informational Message[17-12-2013 11:52:15] LOG VERSION: 2.0
Informational Message[17-12-2013 11:52:15] Local time is Tue Dec 17 11:52:15 CET 2013
Program Start[17-12-2013 11:52:15] Nagios 4.0.2 starting... (PID=4615)
Informational Message[17-12-2013 11:52:15] Event broker module 'NERD' deinitialized successfully.
Program Restart[17-12-2013 11:52:15] PROGRAM_RESTART event encountered, restarting...
External Command[17-12-2013 11:52:15] EXTERNAL COMMAND: RESTART_PROGRAM;
sreinhardt
-fno-stack-protector
Re: Nagios 4.0.2 not reloading config on restart through .cm
Post by sreinhardt »
There was an issue with this prior to 4.0.2 where a reload(different than restart) was not handling loading\unloading of hosts and services properly. It seems to be fixed with the 4.0.2 release though. I see the log file, but can you confirm that QL is not sending a reload instead? Which command in the QL interface are you using?
iotg
Post by iotg »
Hi there!
Something similar happened to me (Nagios was no restarting from Nagios QL 3.2.0 after upgrade to Nagios Core 4.0.1), so I checked the NagiosQL Support Forum and I found this link: http://www.nagiosql.org/forum8/installa ... mitstart=0 So I did the changes posted and apparently nagios is now restarting from Nagios QL (below the event log from nagios console):
[12-16-2013 08:59:10] nerd: Fully initialized and ready to rock!
[12-16-2013 08:59:10] nerd: Channel opathchecks registered successfully
[12-16-2013 08:59:10] nerd: Channel servicechecks registered successfully
[12-16-2013 08:59:10] nerd: Channel hostchecks registered successfully
[12-16-2013 08:59:10] qh: core query handler registered
[12-16-2013 08:59:10] qh: Socket '/usr/local/nagios/var/rw/nagios.qh' successfully initialized
[12-16-2013 08:59:10] LOG VERSION: 2.0
[12-16-2013 08:59:10] Local time is Mon Dec 16 08:59:10 CST 2013
[12-16-2013 08:59:10] Nagios 4.0.1 starting... (PID=29402)
[12-16-2013 08:59:10] Warning: command_check_interval is deprecated and will be removed. Commands are always handled on arrival
[12-16-2013 08:59:10] Warning: external_command_buffer_slots is deprecated and will be removed. All commands are always processed upon arrival
[12-16-2013 08:59:10] Warning: sleep_time is deprecated and will be removed.
[12-16-2013 08:59:10] Warning: p1_file is deprecated and will be removed.
[12-16-2013 08:59:10] Warning: enable_embedded_perl is deprecated and will be removed.
[12-16-2013 08:59:10] Warning: use_embedded_perl_implicitly is deprecated and will be removed.
[12-16-2013 08:59:10] Event broker module 'NERD' deinitialized successfully.
[12-16-2013 08:59:10] PROGRAM_RESTART event encountered, restarting...
[12-16-2013 08:59:10] EXTERNAL COMMAND: RESTART_PROGRAM;
As I said, it seems that Nagios is now restarting but the changes that I´m doing in NagiosQL are not effective into Nagios unless I restart nagios from CLI (doing a service nagios restart, or service nagios stop and then start).
As an additional note, If I do a service nagios reload from CLI... Same thing (host checks and service checks are not taking effect)
Your help will be really appreciated.
Cheers.
sreinhardt
Please open your own thread, as this is somewhat different being 4.0.1. Additionally I believe 4.0.2 had a fix that resolved this issue, so I would suggest updating. Checking the changelog is not a bad idea either.
c0ntra
Post by c0ntra »
I'm also experiencing this issue with Nagios 4.0.2 except I'm not using NagiosQL; instead I'm simply reloading from the linux shell. I went over the changes listed for Bug 492 [http://sourceforge.net/p/nagios/nagiosc ... c89f91d27/], and it seems my init script is all up-to-date, but i'm still not able to see any service or host changes in the nagios web interface unless I stop the service, and then start it up again.
Any ideas?
abrist
Red Shirt
Post by abrist »
What platform/os are you running nagios on? I ask because there are still some issues with the init script on suse, debian and friends, among a few others.
