Log entry for Notification Disable?
matt.uebel
When a user submits the command to disable notifications for a host or service, is there any logging available to track this?
Re: Log entry for Notification Disable?
Nagios XI includes an "Audit Log". Go to --> Admin --> System Information --> Audit Log.
matt.uebel
Thanks, I have found these log entries.
Is there anything that would cause a host to notify even when Notifications are disabled? I see one of my users disabled notifications for a host, but then 20 minutes later, and a few more times over the night, the host still notified.
There are a few different methods for disabling notifications, what method did your user use to disable notifications?
matt.uebel
Clicking the "Disable Notifications" link in the Quick Actions panel of the Host Status Detail page was the method to disable notifications.
Were you receiving notifications to just the user in question? Or to all contacts on the disabled object?
matt.uebel
We received notifications for all users.
But did you receive notifications for your contacts as well? "Not users, just contacts."
matt.uebel
yeah, it was basically all contacts that would normally receive notifications if the host had notifications enabled. Cell Phone of the CIO and everything
matt.uebel
thank you sir, figured out the issue. The user had not actually disabled notifications for the correct host, so user error and not nagios error in this case.
