Setup Switchvox OID's in serivces
nhajicostis
I need some help configuring services to monitor Digium Switchvox PBX, I have the host setup for my remote PBX's working fine, now I am trying to monitor specific OID's through SNMP and I cannot get the output to work, does anyone have a good tutorial on how to accomplish this.
Nick Hajicostis
Nick Hajicostis
Re: Setup Switchvox OID's in serivces
You can use the nagios-plugin "check_snmp" to check these specific oids. You will need to use snmpwalk to identify the oids you wish to monitor if you have not previously identified them. Additionally, port 161 needs to be open and an snmp daemon must be running on the remote device.
https://www.nagios-plugins.org/doc/man/check_snmp.html
http://www.net-snmp.org/docs/man/snmpwalk.html
http://net-snmp.sourceforge.net/docs/man/snmpget.html
This is actually a pretty good example:
http://www.linuxjournal.com/magazine/sn ... ing-nagios
It will differ from what you are doing though. Are you using the check_snmp plugin to run active get requests against your OID's? Can you show us an example of you running it against one of your Switchvox OID's, and it's output?
nhajicostis
Thanks for the replies, I have a feeling my problem might be the check-snmp plugin is not installed. I will try to get some examples during the next 24 hour
No problem. Let us know when you have some results.
nhajicostis
I do have a question, I will preface this with I am a noob when it comes to Nagios, I have a MIB for the OID's I want to use, how do I get Nagios to interpret that file. I used snmpwalk to test the OID's and I get valid data back while in terminal, now I need to setup my service in Nagios to read this OID and send out alerts if a threshold is passed. This is where I am stuck in my configuration. Any help will be greatly appreciated.
Nick
Nick
nhajicostis
I am running into another problem, while testing using snmpwalk, I try to view info off a remote device, using command snmpwalk -v 2c -c public (remote IP address) (OID)
When I use the same command but the IP address is my local Swichvox on the LAN, I get the correct info, when I put in the IP of a remote Switchvox, that the snmp daemon is running on and the firewall is pointing port 161 to the local address of the Switchvox, I get a timeout. Any ideas as to why this is happening. The firewall is a Watchguard XTM router and I am using a Static NAT to route to the Switchvox in my firewall rules.
Nick
Nick
If you have a .mib file, install it in /usr/share/snmp/mibs. That's optional, but it allows you to use a human-readable OID instead of the string of numbers. Then you can set a generic check_snmp command and a service check. I define custom host macros in my host definitions so I can use the same service definition for multiple temperature sensors which all need slightly different thresholds.nhajicostis wrote:I have a MIB for the OID's I want to use, how do I get Nagios to interpret that file. I used snmpwalk to test the OID's and I get valid data back while in terminal, now I need to setup my service in Nagios to read this OID and send out alerts if a threshold is passed.
command_name check_snmp
# $ARG1$ = OID, $ARG2$ = warning threshold, $ARG3$ = critical threshold, $ARG4$ = label, $ARG5$ = units
command_line $USER1$/check_snmp $HOSTADDRESS$ -o $ARG1$ -w $ARG2$ -c $ARG3$ -C communityreadstring -l $ARG4$ -u $ARG5$
use standard_service
hostgroup_name env1
service_description Temperature 1
check_command check_snmp!temperatureSensor1CurrentValue.0!$_temp1warn$!$_temp1crit$!"Temperature Sensor 1:"!"deg. F"
define host {
use network_switch
host_name foo
alias foo
address foo
host_groups env1,env2
_hum1warn 56
_hum1crit 60
_hum2warn 56
_hum2crit 60
_temp1warn 83
_temp1crit 85
_temp2warn 85
_temp2crit 87
sreinhardt
- -fno-stack-protector
thanks cbeattie! nhajicostis are you able to see the traffic pass through your firewall? Is there any possibility of running a tcpdump on the switchvox device for port 161 to validate that traffic is actually incoming? Additionally, since it is udp and not tcp, it does not keep a continual stream and will respond on a random port so the firewall may be blocking only the return traffic, just as another thing to look for in your firewall logs.
nhajicostis
Here is an update, I have got the check_snmp command to work, the plugin did not compile the first time since i did not have Net-SNMP installed. I get data off my local PBX no problem, I have 1 issue there that the critical threshold I defined is not working, the syntax i am using is as follows check_snmp!-C public -o SWITCHVOX-MIB::svoxAvailableVoipProviders -c <3 . the integer value it pulls is 2, should this work, I read this as if value is less than 3 then Crit, if I am using this argument wrong can someone please show me the proper usage. All of my critical thresholds are less than or greater than arguments.
As well i still can't get any remote queries to work I still get timeout, I have configured both routers at each end to route port udp 161 to either the PBX or the Nagios server depending on which end i am at.
Any help on these issues would be greatly appreciated thanks
Nick Hajicostis
Nick Hajicostis
