PHP Deprecated: Function eregi() is deprecated
zaji_nms
Post by zaji_nms »
[Wed Dec 18 08:43:49 2013] [error] [client x.x.x.x] PHP Deprecated: Function eregi() is deprecated in /usr/local/nagios/share/pnp/include/function.inc.php on line 1553, referer: http://x.x.x.x/nagios/pnp/index.php/gra ... tEthernet2
i have added a new function interfacetable_v3t in nagios as i want to monitor bult subinterface bandwidth and performance thorough this plugin but i am getting above error how do i fix it ?
Zajil NMS
Re: PHP Deprecated: Function eregi() is deprecated
Please do not post questions in unrelated threads. I have split your post from the thread and started a new one.
zaji_nms
Post by zaji_nms »
really i was not knowing that , my intense was not bad. i wanted that issue to be fix. next time i will take care.
Zajil NMS
abrist
Red Shirt
Post by abrist »
What version of XI are you running?
How about php?
yum list installed | grep php
zaji_nms
Post by zaji_nms »
NagiosXI version : 2012R1.8
[root@localhost ~]# yum list installed | grep php
php.x86_64 5.3.3-14.el6_3 @updates
php-cli.x86_64 5.3.3-14.el6_3 @updates
php-common.x86_64 5.3.3-14.el6_3 @updates
php-gd.x86_64 5.3.3-14.el6_3 @updates
php-mbstring.x86_64 5.3.3-14.el6_3 @updates
php-mcrypt.x86_64 5.3.3-1.el6 @epel
php-mssql.x86_64 5.3.3-1.el6 @epel
php-mysql.x86_64 5.3.3-14.el6_3 @updates
php-pdo.x86_64 5.3.3-14.el6_3 @updates
php-pear.noarch 1:1.9.4-4.el6 @base
php-pear-HTML-Template-IT.noarch
1.3.0-2.el5 @/php-pear-HTML-Template-IT-1.3.0-2.el5.noarch
php-pgsql.x86_64 5.3.3-14.el6_3 @updates
php-snmp.x86_64 5.3.3-14.el6_3 @updates
php-xml.x86_64 5.3.3-14.el6_3 @updates
Zajil NMS
We have never recommending using the pnp links directly as you have shown for Nagios XI, you should use the following to get the image for the graphs
http://x.x.x.x/nagiosxi/includes/components/perfdata/graphApi.php?host=xx-xx-2&service=If_GigabitEthernet2
This does some error handling on old code in PNP
