I have a problem with "VMware Runtime Issues" in check_esx.
Nagios shows that:
CHECK_ESX CRITICAL - Can't call method "name" on an undefined value at /usr/local/nagios/libexec/check_esx line 1292.
So I checked this line and there is a piece of code:
elsif (uc($subcommand) eq "ISSUES")
my $issues = $host_view->configIssue;
if (defined($issues))
$output = '';
foreach (@$issues)
/*line 1292*/ $output .= $_->vm->name . ": " . $_->fu$
else
$res = 'OK';
$output = 'No config issues';
thanks for any help.
nagios check_esx
Re: nagios check_esx
Can you post the full service check and command definition? This error is usually due to a missing required field in the check.
service definition:
command definition:
Thanks for answering my question:)
use service
hostgroup_name ESXi Hypervisors
service_description VMware Runtime Issues
check_command check_esx_host_runtime_issues
command_name check_esx_host_runtime_issues
command_line /usr/bin/perl $USER1$/check_esx -H $HOSTADDRESS$ -u nagiosusr -p ********* -l runtime -s issues
check_esx.txt- the full check
- (85.28 KiB) Downloaded 346 times
Reason: removed password
Have you tried this with check_esx3? It is more up to date:
http://exchange.nagios.org/directory/Pl ... st/details
