global_service_event_handler not working
ksd13
Post by ksd13 »
I have been trying to send SNMPtrap using global_service_event_handler and global_host_event_handler but it does not work. Nagios user can execute commands created for this purpose but nothing happens when service/host events are generated. Nagios does recognize global event handlers defined in nagios.cfg on restart.
Thanks in advance for your comments.
# grep global /etc/nagios/nagios.cfg
global_host_event_handler=send-host-trap
global_service_event_handler=send-service-trap
# cat /etc/nagios/commands.cfg
#'send-service-trap' command definition
command_name send-service-trap
command_line /usr/local/bin/send-service-trap snmp_host_IP public "$HOSTNAME$" "$SERVICEDESC$" $SERVICESTATEID$ "$SERVICEOUTPUT$"
# cat /usr/local/bin/send-service-trap
# Arguments:
# $1 = Management Station
# $2 = Community String
# $3 = host_name
# $4 = service_description (Description of the service)
# $5 = return_code (An integer that determines the state
# of the service check, 0=OK, 1=WARNING, 2=CRITICAL,
# 3=UNKNOWN).
# $6 = plugin_output (A text string that should be used
# as the plugin output for the service check)
echo "Service trap sent" | /bin/mailx -s "Service trap sent" [email protected]
sudo /usr/bin/snmptrap -v 2c -c $2 $1 '' NAGIOS-NOTIFY-MIB::nSvcEvent nSvcHostname s "$3" nSvcDesc s "$4" nSvcStateID i $5 nSvcOutput s "$6"
# ls -al /usr/bin/snmptrap
-rwxr-xr-x 1 root root 14648 Aug 24 2011 /usr/bin/snmptrap
wfournier
Re: global_service_event_handler not working
Post by wfournier »
Set log_event_handlers=1 in the nagios.cfg to make sure that the handler is even executed.
You did set enable_event_handlers=1 on nagios.cfg, did you?
ksd13
Post by ksd13 »
I have both parameters enabled but I do not see it executed.
# egrep 'log_event|enable_event_handlers' /etc/nagios/nagios.cfg
sreinhardt
-fno-stack-protector
Post by sreinhardt »
Could you run this for us please and return the output? This is taking into account a source based install generally on Cent\RHEL so the path may need to change for your system.
grep -Ri 'event_handler' /usr/local/nagios/etc/
ksd13
Post by ksd13 »
# grep -Ri 'event_handler' /etc/nagios
/etc/nagios/.#services-infosec.cfg.1.35:event_handler_enabled 1
/etc/nagios/services-infosec.cfg:event_handler_enabled 1
/etc/nagios/hosts-infosec.cfg: event_handler_enabled 1
/etc/nagios/services.cfg:event_handler_enabled 1
/etc/nagios/localhost.cfg: event_handler_enabled 1 ; Host event handler is enabled
/etc/nagios/localhost.cfg: event_handler_enabled 1 ; Service event handler is enabled
/etc/nagios/nagios.cfg:log_event_handlers=1
/etc/nagios/nagios.cfg:#global_host_event_handler=somecommand
/etc/nagios/nagios.cfg:#global_service_event_handler=somecommand
/etc/nagios/nagios.cfg:global_host_event_handler=send-host-trap
/etc/nagios/nagios.cfg:global_service_event_handler=send-service-trap
/etc/nagios/nagios.cfg:event_handler_timeout=30
/etc/nagios/nagios.cfg:enable_event_handlers=1
sreinhardt
OK, all of that looks great, you had me for a second with the commented out global event handler lines. :) Could you run:
grep -i 'handler' /usr/local/nagios/var/nagios.log
ksd13
Post by ksd13 »
Sorry for not removing the commented lines. There are no event handlers reported in the logs.
# grep -i handler /san0/nagios-logs/nagios.log
abrist
Red Shirt
Post by abrist »
You config looks ok. What is event_handler_timeout set to?
grep event_handler_timeout /usr/local/nagios/etc/nagios.cfg
ksd13
Post by ksd13 »
# grep event_handler_timeout /etc/nagios/nagios.cfg
Post by slansing »
Based on what you are triggering, you may want to push that number a bit further out. You would need to make the change, then restart nagios for it to take effect:
http://nagios.manubulon.com/traduction/ ... er_timeout
