Strange, I just noticed that it is using check_nrpe but I have it set to use check_nt?
Anyway, here is the info from configure>ccm>services>diskette icon.
Notes, I have replaced the first 4 characters of the hostname with xxxx in on this posts for some security, it's not edited on the actual nagios server, just here.
# Service configuration file
# Created by: Nagios QL Version 3.0.3
# Date: 2014-01-17 04:11:30
# Version: Nagios 3.x config file
# Nagios QL will overwite all manual settings during the next update
host_name xxxxITXDC02
service_description LDAP
use xiwizard_tcp_service
check_command check_xi_service_tcp!-p 389
max_check_attempts 5
check_interval 5
retry_interval 1
notification_interval 60
contacts nagiosadmin
_xiwizard autodiscovery
register 1
service_description NetBIOS
check_command check_xi_service_tcp!-p 139
check_interval 5
retry_interval 1
register 1
service_description Ping
use xiwizard_genericnetdevice_ping_service
check_interval 5
retry_interval 1
register 1
service_description RDP
check_command check_xi_service_tcp!-p 3389
check_interval 5
retry_interval 1
register 1
# END OF FILE
