Upgraded from 3.5 to 4.0.2. Some cgi modules didn't build
ZaphoidPA
Post by ZaphoidPA »
I have just upgraded from 3.5 to 4.0.2, and noticed that whenever I go to my maps, trends of histogram, I get failure messages, specifically "Error: Could not read object configuration data!".
As I was looking around, I noticed that none of these files were updated when I built the new nagios core. They all have a date stamp of March, not today.
Looking in the cgi source directory, I see that none of these 3 files have been built.
root@nagios:~/nagios-4.0.2/cgi# ls -l histo*
-rw-rw-r-- 1 root root 83318 Nov 25 06:16 histogram.c
-rw-rw-r-- 1 root root 30100 Nov 25 06:16 history.c
-rwxr-xr-x 1 root root 634562 Dec 20 10:24 history.cgi
root@nagios:~/nagios-4.0.2/cgi# ls -l status*
-rw-rw-r-- 1 root root 208448 Nov 25 06:16 status.c
-rwxr-xr-x 1 root root 773457 Dec 20 10:24 status.cgi
-rw-r--r-- 1 root root 16836 Dec 20 10:24 statusdata-cgi.o
-rw-rw-r-- 1 root root 92851 Nov 25 06:16 statusmap.c
-rw-rw-r-- 1 root root 49853 Nov 25 06:16 statuswml.c
-rwxr-xr-x 1 root root 663870 Dec 20 10:24 statuswml.cgi
-rw-rw-r-- 1 root root 36263 Nov 25 06:16 statuswrl.c
-rwxr-xr-x 1 root root 640632 Dec 20 10:24 statuswrl.cgi
root@nagios:~/nagios-4.0.2/cgi# ls -l trends*
-rw-rw-r-- 1 root root 97395 Nov 25 06:16 trends.c
Is there an error in the Makefile that is stopping these modules from being built? As I look through the build spam, I don't even see these three modules being referenced.
sreinhardt
-fno-stack-protector
Re: Upgraded from 3.5 to 4.0.2. Some cgi modules didn't buil
Post by sreinhardt »
No those all should definitely be created, what os are you running on, and what commands for ./configure and make did you run?
ZaphoidPA
Post by ZaphoidPA »
I did:
./configure --with-command-group=nagcmd
make all
make install
I also tried make install-cgi, but that didn't do anything different.
It seems really puzzling that those modules didn't build at all..
O/S info;
uname -a
Linux nagios 2.6.38-16-generic-pae #67~lucid1-Ubuntu SMP Fri Sep 7 18:39:12 UTC 2012 i686 GNU/Linux
abrist
Red Shirt
Post by abrist »
Are you sure you have all the necessary dependencies? The maps will not build if packages like gd and its associated dependencies are not available. Can you attach a log of the compile to you next post?
ZaphoidPA
Post by ZaphoidPA »
So.. It was indeed GD that was missing. I had missed a warning message in the information that ./configure produced.
It was an ubuntu install, so it was a pretty simple matter to apt-get install libgd2-xpm-dev, reboot, and the build worked flawlessly after that!
Richard.
sreinhardt
Awesome glad its working! Locking this up then.
