NRPE multiple PID
peter.romfeld.hk
NRPE multiple PID
Post by peter.romfeld.hk »
on only one of my nagios server i have a strange NRPE behavior. It shows multiple running PID (pid 27377 27372 27294). Even after restart it still shows multiple PID. After STOP/START its back to one PID
Any explanation? Should I be concerned about compromised server?
Cheers,
Peter
Re: NRPE multiple PID
Post by slansing »
Are you running a NRPE server, as well as client on the system? Are you checking anything on this server from another one via NRPE? When you kill the processes and restart the NRPE daemon how long does it take for you to see additional processes? When you see all three please run the following and share the output:
ps -ef | grep nrpe
peter.romfeld.hk
Yes I am also running nrpe. I have 2 Nagios servers which also check each other :D
I didnt got multiple PID's so far.
Peter
Post by slansing »
Please run the above command and share the output when you see the suspected "3 pids."
