Checking via SSH
BanditBBS
Checking via SSH
Post by BanditBBS »
We have started checking some servers via ssh, and not the conventional method. we are not using the check_by_ssh method or connecting and running script installed on the remote machine. Instead, we are using this command(with ssh keys set between the servers):
ssh nagios@$HOSTADDRESS$ 'bash -s' -- < $USER1$/$ARG1$ $ARG2$
And then we are using some custom scripts to do the basic disk, mem and cpu checks. Is there any issue doing checks using this method that you can think of? The checks have to be a script, can't be a compile program like the default check_mem or check_disk is the biggest issue I can think of, any others?
This group wants to use this method so the scripts don't need copied and/or updated multiple places, just the nagios server.
2 of XI5.6.14 Prod/DR/DEV - Nagios LogServer 2 Nodes
See my projects on the Exchange at BanditBBS - Also check out my Nagios stuff on my personal page at Bandit's Home and at github
Re: Checking via SSH
Post by slansing »
Sounds interesting... :). You will also need to make sure you get the return output from your scripts in a valid fashion "of course," also, if your scripts may take a bit longer to execute or return the session will need to be kept open so they don't get cut off, if that makes sense. Are you going to give nagios some more sudoers rules to run these ssh based check commands? "I've not personally tested this, you may not have to."
BanditBBS
Post by BanditBBS »
As of right now, I am just checking disk, CPU and ram. CPU check is just parsing data from iostat and disk is parsing data from df. The mem check is basically doing something similar, so special perms have not been needed yet.
edited for missing the word "not"
I haven't tested this either, but I am going to give it a try. BanditBBS, you never run out of ideas! :D
