If you generate an availability report for a servicegroup setting "includesoftstates=yes" the report's values are generated correctly.
Unfortunately, all links to specific service's reports do not include the "includesoftstates" url parameter.
I filed it at http://tracker.nagios.org/view.php?id=551 where I also include a patch.
What've I done wrong? Can this be included upstream? What can I do further if not?
Thanks!
[PATCH] Group report omits includesoftstates in links
Re: [PATCH] Group report omits includesoftstates in links
I'm no dev, but this looks like a pretty concise fix. Of course before we include it a dev would need to take a look, so if that does happen there should be a note in the report you submitted.
