Can I define a service as a parent of a host
BanditBBS
Post by BanditBBS »
I looked here : http://nagios.sourceforge.net/docs/3_0/ ... .html#host and it says the parents is comma list of hosts. But can I specify a service instead?
Example: I want to specify the service check of a particular link as the parent for a remote router. The reason, the router with the link may still be up, just the circuit could be down.
2 of XI5.6.14 Prod/DR/DEV - Nagios LogServer 2 Nodes
See my projects on the Exchange at BanditBBS - Also check out my Nagios stuff on my personal page at Bandit's Home and at github
Re: Can I define a service as a parent of a host
No, but you can do this by setting up dependencies in the CCM
BanditBBS
Post by BanditBBS »
scottwilkerson wrote:No, but you can do this by setting up dependencies in the CCM
That is what I figured...go ahead and close....thanks.
