I am using WhatsAPI, a bit customized for my needs. Its working fine from the commandline:
/usr/lib64/nagios/plugins/send_whatsapp.php args1 args2 args3 args4 args5 args6 CONTACTPAGER
But Nagios is not executing it, here my config:
commands.cfg:
# 'notify-host-by-xmpp' command definition
command_name notify-host-by-xmpp
command_line /usr/lib64/nagios/plugins/send_alert.php $NOTIFICATIONTYPE$ $HOSTNAME$ $HOSTSTATE$ $HOSTADDRESS$ $HOSTOUTPUT$ $LONGDATETIME$ $CONTACTPAGER$
# 'notify-service-by-xmpp' command definition
command_name notify-service-by-xmpp
command_line /usr/lib64/nagios/plugins/send_alert.php $NOTIFICATIONTYPE$ $SERVICEDESC$ $HOSTALIAS$ $HOSTADDRESS$ $SERVICESTATE$ $LONGDATETIME$ $CONTACTPAGER$
templates.cfg:
define contact{
name xmpp-contact
service_notification_options w,u,c,r
host_notification_options d,u,r
service_notification_commands notify-service-by-xmpp
host_notification_commands notify-host-by-xmpp
register 0
service_notification_period 24x7
host_notification_period 24x7
contacts.cfg
define contact{
contact_name peter
use xmpp-contact
alias peter sms
pager mynumber
define contactgroup{
contactgroup_name admins
alias Nagios Administrators
members alerts, peter
I had the same config for my send_sms.py script which was working just fine.
In the logs i see that nagios actually trigger the notification. but in the php log i dont see that nagios executed it
[1388980882] SERVICE NOTIFICATION: peter;region-nagios;NAGIOS;OK;notify-service-by-xmpp;NAGIOS OK: 2 processes, status log updated 9 seconds ago
Notifications to WhatsAPP
peter.romfeld.hk
Re: Notifications to WhatsAPP
solved with using yowsup.
you need to define countycode, autodetect not working. I am using my own python script to generate the message and forward it to yowsup-cli
