One Windows machine at a time?
4430salton
Post by 4430salton »
Hello Nagios experts,
I have installed and have working Nagios version 3.5.1. I have configured at least 5 windows .cfg files and have them defined in nagios,cfg file. My problem is I can only see one windows computer at a time?!? If I delete the pound sign on more than one, then I get the error "Running configuration check...... CONFIG ERROR! Restart aborted. Check your Nagios configuration." after I do the recompile "service nagios restart"
# Definitions for monitoring a Windows machine
#cfg_file=/etc/nagios/objects/windows.cfg
#cfg_file=/etc/nagios/objects/tbd-1wefrg.cfg
#cfg_file=/etc/nagios/objects/tbdwwdsxrf5.cfg
#cfg_file=/etc/nagios/objects/tbd-gwer53.cfg
cfg_file=/etc/nagios/objects/tbd-1wds34tg.cfg
I can delete the pound sign on each of the above .cfg files, one at a time, but if I do more than one then it errors out. What am I doing wrong or what did I forget? Thanks for your help!
Re: One Windows machine at a time?
Can you post the last 50 or so lines of the configuration check output?
4430salton
sorry not that familiar with your request, do you want to see the nagios.log file?
abrist
Red Shirt
Post by abrist »
Post the output of the following in code wraps:
usr/local/nagios/bin/nagios -v /usr/local/nagios/etc/nagios.cfg
4430salton
I am still learning about nagios and linux.
Is this what you want?
ran the command from where nagios installed itself...which was /etc/nagios
Processing object config file '/etc/nagios/objects/tbd-g8217k1.cfg'...
Processing object config file '/etc/nagios/objects/tbd-bxd4zd1.cfg'...
Warning: Duplicate definition found for hostgroup 'windows-servers' (config file '/etc/nagios/objects/tbd-bxd4zd1.cfg', starting on line 47)
Error: Could not add object property in file '/etc/nagios/objects/tbd-bxd4zd1.cfg' on line 48.
Post by slansing »
Please attach the config file named "tbd-bxd4zd1.cfg"
4430salton
the command I ran was
/etc/nagios/nagios -v /etc/nagios/nagios.cfg
that is what you were wanting correct?
sreinhardt
-fno-stack-protector
Post by sreinhardt »
Yes that is what we needed initially, now we would like to see the configuration file listed above as it is causing duplicate entry issues and errors.
4430salton
I was trying to keep actual computer names anonymous. hold on
4430salton
sorry for not getting back sooner. but I found the problem with that file. the problem is the hostgroup called 'windows-servers' if I have that named in other windows .cfg files it wont compile. i put the pound sign in and disable hostgroups in the other cfg files and eventually everything will compile. i know this is not good nagios mgmt but I am trying to learn Centos and Nagios at the same time and it can be a bit challenging. maybe you can point in the direction of a good explanation of how to create hostgroups correctly?
