CentOS 32 Bit 5.6
Manual Install
No special configs
Im trying to get this up and running, and it so far, whenever I add 2 switches in particular, I get the issue where applying config just sits there, and times out giving me .... I kill and restart nagios, and then check the services for the switches, and any device added after it (linux server in the most recent case), and they all say Sync Missed. I go to Write Config Files, hit all the buttons there, no errors. I go to Apply Configuration, and have no issues there. Ive deleted all services and hosts for the 2 switches and linux server. Any config I add after that, excluding the 2 switches and linux server from before, also say Sync Missed. When going thru the Config Wizard the switches are polled correctly, showing port name and speed correctly. I can just never get the services going to get them to report to the XI server. Heres most recent config snapshot:
Nagios Core 3.2.3
Copyright (c) 2009-2010 Nagios Core Development Team and Community Contributors
Last Modified: 10-03-2010
License: GPL
Reading configuration data...
Read main config file okay...
Processing object config directory '/usr/local/nagios/etc/static'...
Processing object config file '/usr/local/nagios/etc/static/xitemplates.cfg'...
Processing object config file '/usr/local/nagios/etc/static/xitest.cfg'...
Processing object config file '/usr/local/nagios/etc/static/xiobjects.cfg'...
Processing object config file '/usr/local/nagios/etc/contacttemplates.cfg'...
Processing object config file '/usr/local/nagios/etc/contactgroups.cfg'...
Processing object config file '/usr/local/nagios/etc/contacts.cfg'...
Processing object config file '/usr/local/nagios/etc/timeperiods.cfg'...
Processing object config file '/usr/local/nagios/etc/commands.cfg'...
Processing object config file '/usr/local/nagios/etc/hostgroups.cfg'...
Processing object config file '/usr/local/nagios/etc/servicegroups.cfg'...
Processing object config file '/usr/local/nagios/etc/hosttemplates.cfg'...
Processing object config file '/usr/local/nagios/etc/servicetemplates.cfg'...
Processing object config file '/usr/local/nagios/etc/servicedependencies.cfg'...
Processing object config file '/usr/local/nagios/etc/serviceescalations.cfg'...
Processing object config file '/usr/local/nagios/etc/hostdependencies.cfg'...
Processing object config file '/usr/local/nagios/etc/hostescalations.cfg'...
Processing object config file '/usr/local/nagios/etc/hostextinfo.cfg'...
Processing object config file '/usr/local/nagios/etc/serviceextinfo.cfg'...
Processing object config directory '/usr/local/nagios/etc/hosts'...
Processing object config file '/usr/local/nagios/etc/hosts/localhost.cfg'...
Processing object config file '/usr/local/nagios/etc/hosts/Lykes BigIron 4000.cfg'...
Processing object config file '/usr/local/nagios/etc/hosts/DC1 HV Big Iron RX.cfg'...
Processing object config file '/usr/local/nagios/etc/hosts/DC1 BigIron RX Tagged.cfg'...
Processing object config file '/usr/local/nagios/etc/hosts/DC1 Core v26-27.cfg'...
Processing object config file '/usr/local/nagios/etc/hosts/Tarkin.cfg'...
Processing object config directory '/usr/local/nagios/etc/services'...
Processing object config file '/usr/local/nagios/etc/services/localhost.cfg'...
Processing object config file '/usr/local/nagios/etc/services/Lykes BigIron 4000.cfg'...
Processing object config file '/usr/local/nagios/etc/services/DC1 HV Big Iron RX.cfg'...
Processing object config file '/usr/local/nagios/etc/services/DC1 BigIron RX Tagged.cfg'...
Processing object config file '/usr/local/nagios/etc/services/DC1 Core v26-27.cfg'...
Checking services...
Checked 379 services.
Checking hosts...
Checked 6 hosts.
Checking host groups...
Checked 4 host groups.
Checking service groups...
Checked 1 service groups.
Checking contacts...
Checked 2 contacts.
Checking contact groups...
Checked 2 contact groups.
Checking service escalations...
Checking service dependencies...
Checked 0 service dependencies.
Checking host escalations...
Checked 0 host escalations.
Checking host dependencies...
Checked 0 host dependencies.
Checking commands...
Checked 75 commands.
Checking time periods...
Checked 8 time periods.
Checking for circular paths between hosts...
Checking for circular host and service dependencies...
Checking misc settings...
Total Warnings: 0
Total Errors: 0
Switches are Foundry FESX. Linux server is CentOS VMware Image. I have wiped and reloaded once already, the first time the linux server did report fine. The 2 switches mentioned gave me the sync missed issue in the first install, hence the reload.
Id appreciate any help I can get. Need to get a demo of our network going for the BTP. Thanks!
Tom
