Got error when running plugin check_tomcat.pl
Frédéric GRANAT
Post by Frédéric GRANAT »
I've got the followin error when running : /usr/local/nagios/libexec/check_tomcat.pl -H server (I downloaded it from http://exchange.nagios.org/directory/Pl ... pl/details)
Can't locate XML/XPath.pm in @INC (@INC contains: /usr/lib/perl5/site_perl/5.8.8 /i386-linux-thread-multi /usr/lib/perl5/site_perl/5.8.8 /usr/lib/perl5/site_perl /usr/lib/perl5/vendor_perl/5.8.8/i386-linux-thread-multi /usr/lib/perl5/vendor_ perl/5.8.8 /usr/lib/perl5/vendor_perl /usr/lib/perl5/5.8.8/i386-linux-thread-mul ti /usr/lib/perl5/5.8.8 .) at ./check_tomcat.pl line 27.
BEGIN failed--compilation aborted at ./check_tomcat.pl line 27.
Seems I need to install :
LWP - The World-Wide Web library for Perl
XML::XPath - for parsing and evaluating XPath statements
How could I easily install that ?
Please help me.
Frederic
Re: Got error when running plugin check_tomcat.pl
If you are on a system that uses Yum to manage packages, you can do:
yum install perl-libwww-perl perl-XML-XPath
Frédéric GRANAT
Perfect, I installed it
Now I've got the following error :
Testing check from command line...
COMMAND: /usr/local/nagios/libexec/check_tomcat.pl -H IP -p 8086 -l -a -w -c
OUTPUT: WARNING: http://IP:8086/manager/status?XML=true HTTP/1.1 401 Non-Autoris
How can I do ?
Post by slansing »
Make sure the username and password are correct when you run the plugin script. The user MUST be assigned on the Apache tomcat server with manager privileges.
Frédéric GRANAT
Thank you very much.
It works fine now.
You can close the post
Frederic
