Im running Nagios Core Version 3.2.3 on a Red Hat Enterprise Linux Server release 5.4 (Tikanga).
I created a script (VBScript) to monitor Window's date and time. As i understand, the Nagios Plugins exit status are the following:
0 = OK
1 = Warning
2 = Critical
3 = Unknown
My script never return 3 as exit status, it only return 0, 1 or 2 (depending on the result of it, cause it checks if its syncronized against another server).
The scripts works fine all the time, however, in random moments (approximately once every 3 or 4 hours) nagios report me things like this:
[06-10-2011 04:11:00] SERVICE ALERT: MyServer;Win Clock;OK;SOFT;2;NTP OK: Offset 0 secs.
[06-10-2011 04:10:00] SERVICE ALERT: MyServer;Win Clock;UNKNOWN;SOFT;1;NTP OK: Offset 0 secs.
Option Explicit
On Error Resume Next
Dim strCommand, objProc, objShell, input, strOutput, myRegExp, myMatches, myMatch, Status, result, Args, warn, crit, serverlist, criteria, i
Set Args = WScript.Arguments
criteria="least"
i=0
Err = 0
' Funcion que captura los argumentos.
Function CaptureArguments()
for i=0 to WScript.Arguments.Count-1
Select Case Args.Item(i)
Case "-H" , "-h", "--help", "--HELP", "--Help", "/?", "/Help", "/HELP", "/help"
ShowHelp
Salir
Case "-R", "-r", "--readme", "--README", "--ReadMe", "/r", "/R", "/readme", "/README", "/ReadMe"
ShowReadMe
Salir
Case "-V", "-v", "--version", "--VERSION", "--Version", "/V", "/v", "/Version", "/VERSION", "/version"
ShowVersion
Salir
Case "-S", "-s", "--serverlist", "--SERVERLIST", "--ServerList", "/S", "/s", "/ServerList", "/SERVERLIST", "/ServerList"
CheckNextParameter
serverlist = Args.Item(i+1)
i=i+1
Case "-W", "-w", "--warn", "--WARN", "--Warn", "--warning", "--WARNING", "--Warning", "/W", "/w", "/warn", "/WARN", "/Warn", "/warning", "/WARNING", "/Warning"
CheckNextParameter
warn = Args.Item(i+1)
i=i+1
Case "-C", "-c", "--crit", "--CRIT", "--Crit", "--critical", "--CRITICAL", "--Critical", "/C", "/c", "/crit", "/CRIT", "/Crit", "/critical", "/CRITICAL", "/Critical"
CheckNextParameter
crit = Args.Item(i+1)
i=i+1
Case "-B", "-b", "/B", "/b"
criteria="biggest"
Case Else
wscript.echo "ERROR: Se ingreso un argumento Desconocido o Inesperado. Utilice el Help (/H) o ReadMe (/R)."
Err = 1
Salir
End Select
Next
End Function
' Funcion que verifica la correctitud del proximo parametro utilizado.
Function CheckNextParameter()
' Existe el Argumento para el Parametro?
if (i+1 > WScript.Arguments.Count-1) then
' No, muestro error y salgo.
WScript.echo "ERROR: Falta argumento en parametro " & Args.Item(i) & "."
Err = 1
Salir
end if
' El argumento del parametro contiene un "-" o un "/" (indica el inicio de un nuevo parametro)?
if instr(Args.Item(i+1),"-") OR instr(Args.Item(i+1),"/") then
' Si, muestro error y salgo.
WScript.echo "ERROR: El argumento " & Args.Item(i+1) & " es invalido para el parametro " & Args.Item(i) & "."
Err = 1
Salir
end if
End Function
' Funcion que verifica la correctitud de los Argumentos.
Function CheckArguments()
' Esta definido el parametro warn?
If IsNull(warn) OR (warn = "") Then
WScript.echo "ERROR: El parametro warn (/W) no esta definido."
Err = 1
Salir
End If
' Esta definido el parametro crit?
If IsNull(crit) OR (crit = "") Then
WScript.echo "ERROR: El parametro crit (/C) no esta definido."
Err = 1
Salir
End If
' Esta definido el parametro serverlist?
If IsNull(serverlist) OR (serverlist = "") Then
WScript.echo "ERROR: El parametro serverlist (/S) no esta definido."
Err = 1
Salir
End If
' El argumento warn es numericos?
If IsNumeric(warn) Then
' Si, El argumento warn es un numero entero (verifico si contiene un ".") mayor que 0?
If (not instr(warn,".") = 0) OR (warn <= 0) Then
WScript.Echo "ERROR: El argumento warn (" & warn & ") no es un numero entero mayor a 0."
Err = 1
Salir
Else
' Si, lo convierto a Double.
warn=CDbl(warn)
End If
Else
WScript.Echo "ERROR: El argumento warn (" & warn & ") no es numerico."
Err = 1
Salir
End if
' El argumento crit es numericos?
If IsNumeric(crit) Then
' Si, El argumento crit es un numero entero (verifico si contiene un ".") mayor que 0?
If (not instr(crit,".") = 0) OR (crit <= 0) Then
WScript.Echo "ERROR: El argumento crit (" & crit & ") no es un numero entero mayor a 0."
Err = 1
Salir
Else
crit=CDbl(crit)
End If
Else
WScript.Echo "ERROR: El argumento crit (" & crit & ") no es numerico."
Err = 1
Salir
End if
' El argumento crit es mayor que el argumento warn?
If crit < warn then
WScript.Echo "ERROR: El argumento crit (" & crit & ") es menor que el argumento warn (" & warn & ")"
Err = 1
Salir
End if
End Function
' Funcion que muestra el HELP.
Function ShowHelp()
Wscript.Echo ""
Wscript.Echo "Parametros Descripcion"
Wscript.Echo "/S serverlist Uno o varios servidores separados por coma."
Wscript.Echo "/W warn Warning offset en segundos."
Wscript.Echo "/C crit Critical offset en segundos."
Wscript.Echo "/B Si varios servidores NTPd son especificados, se utilizara el de mayor offset."
Wscript.Echo ""
End Function
' Funcion que muestra la ultima version.
Function ShowVersion()
WScript.Echo "*****"
WScript.Echo " Modificado por: Fabian Olender"
WScript.Echo " Version: 1.2"
WScript.Echo " Fecha: 13/01/2011"
WScript.Echo " Descripcion: Traduccion al Español y arreglo de BUGs en casos que no funcionaba."
End Function
' Funcion que muestra el ReadMe.
Function ShowReadMe()
WScript.Echo ""
WScript.Echo " ----- "
WScript.Echo "| Uso |"
WScript.Echo "Uso: "
WScript.Echo " cscript /NoLogo check_time.vbs serverlist warn crit [biggest]"
WScript.Echo "Ejemplos de Uso: "
Wscript.Echo " cscript /NoLogo check_time.vbs Server1,Server2 0.4 5 biggest"
Wscript.Echo " cscript /NoLogo check_time.vbs www.xxx.yyy.zzz 10 120"
Wscript.Echo " cscript /T:30 /NoLogo check_time.vbs TuDominio.net 120 300"
WScript.Echo ""
WScript.Echo " ------------ "
WScript.Echo "| Parametros |"
Wscript.Echo ""
Wscript.Echo "-H , -h, --help, --HELP, --Help, /?, /Help, /HELP, /help"
Wscript.Echo " Default: Sin Asignar"
Wscript.Echo " Descripcion: Muestra el Help del Script para conocer su funcionamiento."
Wscript.Echo ""
Wscript.Echo "-R, -r, --readme, --README, --ReadMe, /r, /R, /readme, /README, /ReadMe"
Wscript.Echo " Descripcion: Muestra el ReadMe que se esta viendo ahora."
Wscript.Echo ""
Wscript.Echo "-V, -v, --version, --VERSION, --Version, /V, /v, /Version, /VERSION, /version"
Wscript.Echo " Descripcion: Muestra la version actual del Script."
Wscript.Echo "-S, -s, --serverlist, --SERVERLIST, --ServerList, /S, /s, /ServerList, /SERVERLIST, /ServerList"
Wscript.Echo ""
Wscript.Echo " Default: Sin Asignar. Requerido para la ejecucion del Script."
Wscript.Echo " Descripcion: Listado de servidores con NTPd."
Wscript.Echo ""
Wscript.Echo "-W, -w, --warn, --WARN, --Warn, --warning, --WARNING, --Warning, /W, /w, /warn, /WARN, /Warn, /warning, /WARNING, /Warning"
Wscript.Echo " Descripcion: Tiempo en Segundos a partir de generar Warning de Dessincronizacion."
Wscript.Echo " Requerimientos: Valor Entero mayor que 0."
Wscript.Echo ""
Wscript.Echo "-C, -c, --crit, --CRIT, --Crit, --critical, --CRITICAL, --Critical, /C, /c, /crit, /CRIT, /Crit, /critical, /CRITICAL, /Critical"
Wscript.Echo ""
Wscript.Echo "-B, -b, /B, /b"
Wscript.Echo " Default: Desactivado. Se utiliza por defecto el de Mayor Offset. Parametro Opcional"
Wscript.Echo " Descripcion: Si varios servidores NTPd son especificados, se utilizara el de mayor offset."
Wscript.Echo ""
WScript.Echo " ----------- "
WScript.Echo "| Versiones |"
WScript.Echo " Modificado por: Freddy"
WScript.Echo " Version: 1.1"
WScript.Echo " Fecha: 02/12/2010"
WScript.Echo " Descripcion: Modificacion para mejorar performance de pnp4nagios addon y sugerencias para arreglar ciertos casos de mal funcionamiento."
WScript.Echo ""
WScript.Echo " Modificado por: Dmitry Vayntrub ([email protected])"
WScript.Echo " Version: 1.01"
WScript.Echo " Fecha: 17/01/2010"
WScript.Echo " Descripcion: Modificacion general y renombre del script."
WScript.Echo ""
WScript.Echo " Creado por: Mattias Ryrlén (check_ad_time.vbs)"
WScript.Echo " Version: 1.0"
WScript.Echo " Fecha: -"
WScript.Echo " Descripcion: Verifica el time offset de un cliente Windows contra uno o multiples servidor NTPd."
WScript.Echo ""
End Function
' Funcion que ejecuta el comando W32TM y parsea el Output.
Function W32TM()
' Ejecuto el comando w32time.exe
Set objShell = CreateObject("Wscript.Shell")
strCommand = "%SystemRoot%\System32\w32tm.exe /monitor /computers:" & serverlist
set objProc = objShell.Exec(strCommand)
' Parseo el Output para obtener unicamente el NTP offset.
input = ""
strOutput = ""
Do While Not objProc.StdOut.AtEndOfStream
input = objProc.StdOut.ReadLine
If InStr(input, "NTP") Then
strOutput = strOutput & input
End If
Loop
Set myRegExp = New RegExp
myRegExp.IgnoreCase = True
myRegExp.Global = True
myRegExp.Pattern = " NTP: ([+-][0-9]+\.[0-9]+)s"
Set myMatches = myRegExp.Execute(strOutput)
result = ""
If myMatches(0).SubMatches(0) <> "" Then
result = myMatches(0).SubMatches(0)
End If
For Each myMatch in myMatches
If myMatch.SubMatches(0) <> "" Then
If criteria = "biggest" Then
If abs(result) < Abs(myMatch.SubMatches(0)) Then
result = myMatch.SubMatches(0)
End If
Else
If abs(result) > Abs(myMatch.SubMatches(0)) Then
End If
End If
End If
' Wscript.Echo myMatch.SubMatches(0) & " -debug"
Next
End Function
' Funcion que muestra el resultado del Script con el formato adecuado.
Function ShowResult()
' Quito lo que esta despues del ".", quito el signo ("+" o "-") y obtengo el numero.
result=Left(result,instr(result,".")-1)
result=Right(result,Len(result)-1)
result=CDbl(result)
If (result > 0 AND result > crit ) OR (result < 0 AND result < crit) Then
Err = 2
status = "CRITICAL"
Else
If (warn > 0 AND result > warn ) OR (warn < 0 AND result < warn) Then
Err = 1
status = "WARNING"
else
Err = 0
status = "OK"
End If
End If
WScript.Echo "NTP " & status & ": Offset " & result & " secs."
Salir
End Function
Function Salir()
WScript.Quit(Err)
End Function
' # Main #
CaptureArguments
CheckArguments
W32TM
ShowResult
Salir
cscript.exe //T:30 //NoLogo check_time.vbs /S www.xxx.yyy.zzz /W 120 /C 300
* www.xxx.yyy.zzz = NTP Server
[External Scripts]
check_windows_time=cscript.exe //T:30 //NoLogo check_time.vbs /S 10.45.225.11 /W 120 /C 300
;[LUA Scripts]
command[check_windows_time]=cscript.exe //T:30 //NoLogo check_time.vbs /S 10.45.225.11 /W 120 /C 300
host_name MyServer
service_description Win Clock
check_command check_nrpe!check_windows_time
[1307617373.175579] [016.2] [pid=377] Found a check result (#4) to handle...
[1307617373.175615] [016.1] [pid=377] Handling check result for service 'Win Clock' on host 'MyServer'...
[1307617373.175636] [001.0] [pid=377] handle_async_service_check_result()
[1307617373.175657] [016.0] [pid=377] ** Handling check result for service 'Win Clock' on host 'MyServer'...
[1307617373.175676] [016.1] [pid=377] HOST: MyServer, SERVICE: Win Clock, CHECK TYPE: Active, OPTIONS: 0, SCHEDULED: Yes, RESCHEDULE: Yes, EXITED OK: Yes, RETURN CODE: 3, OUTPUT: NTP OK: Offset 1 secs.\n
[1307617373.175755] [016.2] [pid=377] Parsing check output...
[1307617373.175776] [016.2] [pid=377] Short Output: NTP OK: Offset 1 secs.
[1307617373.175822] [016.2] [pid=377] Long Output: NULL
[1307617373.175840] [016.2] [pid=377] Perf Data: NULL
[1307617373.175858] [016.2] [pid=377] ST: HARD CA: 1 MA: 3 CS: 3 LS: 0 LHS: 0
[1307617373.175886] [016.2] [pid=377] Service has changed state since last check!
[1307617373.175918] [016.1] [pid=377] Service is in a non-OK state!
[1307617373.175939] [016.1] [pid=377] Host is currently UP, so we'll recheck its state to make sure...
[1307617373.175959] [001.0] [pid=377] run_async_host_check_3x()
[1307617373.175976] [016.0] [pid=377] ** Running async check of host 'MyServer'...
[1307617373.175996] [001.0] [pid=377] check_host_check_viability_3x()
[1307617373.176017] [001.0] [pid=377] check_time_against_period()
[1307617373.176043] [001.0] [pid=377] check_host_dependencies()
[1307617373.176065] [064.1] [pid=377] Making callbacks (type 14)...
[1307617373.176101] [064.2] [pid=377] Callback #1 (type 14) return code = 0
[1307617373.176122] [016.0] [pid=377] Checking host 'MyServer'...
[1307617373.176141] [001.0] [pid=377] adjust_host_check_attempt_3x()
[1307617373.176161] [016.2] [pid=377] Adjusting check attempt number for host 'MyServer': current attempt=1/10, state=0, state type=1
[1307617373.176230] [016.2] [pid=377] New check attempt number = 1
[1307617373.176347] [001.0] [pid=377] get_raw_command_line()
[1307617373.176396] [2320.2] [pid=377] Raw Command Input: $USER1$/check_ping -H $HOSTADDRESS$ -w 3000.0,80% -c 5000.0,100% -p 5
[1307617373.176417] [2320.2] [pid=377] Expanded Command Output: $USER1$/check_ping -H $HOSTADDRESS$ -w 3000.0,80% -c 5000.0,100% -p 5
[1307617373.176438] [001.0] [pid=377] process_macros()
[1307617373.176457] [2048.1] [pid=377] **** BEGIN MACRO PROCESSING ***********
[1307617373.176477] [2048.1] [pid=377] Processing: '$USER1$/check_ping -H $HOSTADDRESS$ -w 3000.0,80% -c 5000.0,100% -p 5'
[1307617373.176498] [2048.2] [pid=377] Processing part: ''
[1307617373.176515] [2048.2] [pid=377] Not currently in macro. Running output (0): ''
[1307617373.176536] [2048.2] [pid=377] Processing part: 'USER1'
[1307617373.176560] [2048.2] [pid=377] Processed 'USER1', Clean Options: 0, Free: 0
[1307617373.176588] [2048.2] [pid=377] Processed 'USER1', Clean Options: 0, Free: 0
[1307617373.176614] [2048.2] [pid=377] Cleaning options: global=0, local=0, effective=0
[1307617373.176636] [2048.2] [pid=377] Uncleaned macro. Running output (25): '/usr/local/nagios/libexec'
[1307617373.176655] [2048.2] [pid=377] Just finished macro. Running output (25): '/usr/local/nagios/libexec'
[1307617373.176675] [2048.2] [pid=377] Processing part: '/check_ping -H '
[1307617373.176749] [2048.2] [pid=377] Not currently in macro. Running output (40): '/usr/local/nagios/libexec/check_ping -H '
[1307617373.176788] [2048.2] [pid=377] Processing part: 'HOSTADDRESS'
[1307617373.176827] [2048.2] [pid=377] macro_x[2] (HOSTADDRESS) match.
[1307617373.176854] [2048.2] [pid=377] Processed 'HOSTADDRESS', Clean Options: 0, Free: 1
[1307617373.176874] [2048.2] [pid=377] Processed 'HOSTADDRESS', Clean Options: 0, Free: 1
[1307617373.176894] [2048.2] [pid=377] Cleaning options: global=0, local=0, effective=0
[1307617373.176915] [2048.2] [pid=377] Uncleaned macro. Running output (52): '/usr/local/nagios/libexec/check_ping -H My.Server.IP.Address'
[1307617373.176936] [2048.2] [pid=377] Just finished macro. Running output (52): '/usr/local/nagios/libexec/check_ping -H My.Server.IP.Address'
[1307617373.176971] [2048.2] [pid=377] Processing part: ' -w 3000.0,80% -c 5000.0,100% -p 5'
[1307617373.176996] [2048.2] [pid=377] Not currently in macro. Running output (86): '/usr/local/nagios/libexec/check_ping -H My.Server.IP.Address -w 3000.0,80% -c 5000.0,100% -p 5'
[1307617373.177016] [2048.1] [pid=377] Done. Final output: '/usr/local/nagios/libexec/check_ping -H My.Server.IP.Address -w 3000.0,80% -c 5000.0,100% -p 5'
[1307617373.177036] [2048.1] [pid=377] **** END MACRO PROCESSING *************
[1307617373.177126] [016.1] [pid=377] Check result output will be written to '/usr/local/nagios/var/spool/checkresults/checkX3Szdk' (fd=8)
[1307617373.177237] [064.1] [pid=377] Making callbacks (type 14)...
[1307617373.177277] [064.2] [pid=377] Callback #1 (type 14) return code = 0
[1307617373.178927] [016.2] [pid=377] Host check is executing in child process (pid=9253)
[1307617373.182785] [001.0] [pid=9253] process_macros()
[1307617373.183092] [001.0] [pid=9253] process_macros()
[1307617373.183119] [001.0] [pid=9253] process_macros()
[1307617373.183792] [001.0] [pid=9253] process_macros()
[1307617373.183859] [001.0] [pid=9253] process_macros()
[1307617373.183888] [001.0] [pid=9253] process_macros()
[1307617373.196901] [016.1] [pid=377] Current/Max Attempt(s): 1/3
[1307617373.196944] [016.1] [pid=377] Host is UP, so we'll retry the service check...
[1307617373.197046] [001.0] [pid=377] process_macros()
[1307617373.197084] [2048.1] [pid=377] **** BEGIN MACRO PROCESSING ***********
[1307617373.197130] [2048.1] [pid=377] Processing: 'SERVICE ALERT: MyServer;Win Clock;$SERVICESTATE$;$SERVICESTATETYPE$;$SERVICEATTEMPT$;NTP OK: Offset 1 secs.
[1307617373.197170] [2048.2] [pid=377] Processing part: 'SERVICE ALERT: MyServer;Win Clock;'
[1307617373.197228] [2048.2] [pid=377] Not currently in macro. Running output (31): 'SERVICE ALERT: MyServer;Win Clock;'
[1307617373.197251] [2048.2] [pid=377] Processing part: 'SERVICESTATE'
[1307617373.197359] [2048.2] [pid=377] macro_x[4] (SERVICESTATE) match.
[1307617373.197383] [2048.2] [pid=377] Processed 'SERVICESTATE', Clean Options: 0, Free: 1
[1307617373.197417] [2048.2] [pid=377] Processed 'SERVICESTATE', Clean Options: 0, Free: 1
[1307617373.197445] [2048.2] [pid=377] Cleaning options: global=0, local=0, effective=0
[1307617373.197503] [2048.2] [pid=377] Uncleaned macro. Running output (38): 'SERVICE ALERT: MyServer;Win Clock;UNKNOWN'
[1307617373.197526] [2048.2] [pid=377] Just finished macro. Running output (38): 'SERVICE ALERT: MyServer;Win Clock;UNKNOWN'
[1307617373.197547] [2048.2] [pid=377] Processing part: ';'
[1307617373.197566] [2048.2] [pid=377] Not currently in macro. Running output (39): 'SERVICE ALERT: MyServer;Win Clock;UNKNOWN;'
[1307617373.197586] [2048.2] [pid=377] Processing part: 'SERVICESTATETYPE'
[1307617373.197608] [2048.2] [pid=377] macro_x[42] (SERVICESTATETYPE) match.
[1307617373.197629] [2048.2] [pid=377] Processed 'SERVICESTATETYPE', Clean Options: 0, Free: 1
[1307617373.197649] [2048.2] [pid=377] Processed 'SERVICESTATETYPE', Clean Options: 0, Free: 1
[1307617373.197670] [2048.2] [pid=377] Cleaning options: global=0, local=0, effective=0
[1307617373.197726] [2048.2] [pid=377] Just finished macro. Running output (43): 'SERVICE ALERT: MyServer;Win Clock;UNKNOWN;SOFT'
[1307617373.197747] [2048.2] [pid=377] Processing part: ';'
[1307617373.197766] [2048.2] [pid=377] Not currently in macro. Running output (44): 'SERVICE ALERT: MyServer;Win Clock;UNKNOWN;SOFT;'
[1307617373.197787] [2048.2] [pid=377] Processing part: 'SERVICEATTEMPT'
[1307617373.197808] [2048.2] [pid=377] macro_x[6] (SERVICEATTEMPT) match.
[1307617373.197831] [2048.2] [pid=377] Processed 'SERVICEATTEMPT', Clean Options: 0, Free: 1
[1307617373.197851] [2048.2] [pid=377] Processed 'SERVICEATTEMPT', Clean Options: 0, Free: 1
[1307617373.197871] [2048.2] [pid=377] Cleaning options: global=0, local=0, effective=0
[1307617373.197893] [2048.2] [pid=377] Uncleaned macro. Running output (45): 'SERVICE ALERT: MyServer;Win Clock;UNKNOWN;SOFT;1'
[1307617373.197911] [2048.2] [pid=377] Just finished macro. Running output (45): 'SERVICE ALERT: MyServer;Win Clock;UNKNOWN;SOFT;1'
[1307617373.197931] [2048.2] [pid=377] Processing part: ';NTP OK: Offset 1 secs.'
[1307617373.197953] [2048.2] [pid=377] Not currently in macro. Running output (69): 'SERVICE ALERT: MyServer;Win Clock;UNKNOWN;SOFT;1;NTP OK: Offset 1 secs.'
[1307617373.197973] [2048.1] [pid=377] Done. Final output: 'SERVICE ALERT: MyServer;Win Clock;UNKNOWN;SOFT;1;NTP OK: Offset 1 secs.'
[1307617373.197994] [2048.1] [pid=377] **** END MACRO PROCESSING *************
[1307617373.198388] [064.1] [pid=377] Making callbacks (type 9)...
[1307617373.198523] [064.2] [pid=377] Callback #1 (type 9) return code = 0
[1307617373.198555] [001.0] [pid=377] handle_service_event()
[1307617373.198575] [064.1] [pid=377] Making callbacks (type 30)...
[1307617373.198619] [064.2] [pid=377] Callback #1 (type 30) return code = 0
[1307617373.198647] [001.0] [pid=377] run_global_service_event_handler()
[1307617373.198669] [001.0] [pid=377] check_for_external_commands()
[1307617373.198695] [016.1] [pid=377] Rescheduling next check of service at Thu Jun 9 08:03:45 2011
[1307617373.198715] [001.0] [pid=377] get_next_valid_time()
[1307617373.198734] [001.0] [pid=377] check_time_against_period()
[1307617373.198762] [001.0] [pid=377] schedule_service_check()
[1307617373.198783] [016.0] [pid=377] Scheduling a non-forced, active check of service 'Win Clock' on host 'MyServer' @ Thu Jun 9 08:03:45 2011
[1307617373.198837] [016.2] [pid=377] Scheduling new service check event.
[1307617373.198859] [001.0] [pid=377] reschedule_event()
[1307617373.198877] [001.0] [pid=377] add_event()
[1307617373.198900] [064.1] [pid=377] Making callbacks (type 8)...
[1307617373.198935] [064.2] [pid=377] Callback #1 (type 8) return code = 0
[1307617373.198990] [064.1] [pid=377] Making callbacks (type 20)...
[1307617373.199051] [064.2] [pid=377] Callback #1 (type 20) return code = 0
[1307617373.199075] [064.1] [pid=377] Making callbacks (type 13)...
[1307617373.199114] [064.2] [pid=377] Callback #1 (type 13) return code = 0
[1307617373.199171] [064.1] [pid=377] Making callbacks (type 20)...
[1307617373.199230] [064.2] [pid=377] Callback #1 (type 20) return code = 0
[1307617373.199275] [001.0] [pid=377] check_for_service_flapping()
[1307617373.199309] [016.1] [pid=377] Checking service 'Win Clock' on host 'MyServer' for flapping...
[1307617373.199331] [001.0] [pid=377] check_for_host_flapping()
[1307617373.199361] [016.1] [pid=377] Checking host 'MyServer' for flapping...
[1307617373.199414] [016.2] [pid=377] LFT=5.00, HFT=20.00, CPC=0.00, PSC=0.00%
[1307617373.199440] [016.1] [pid=377] Host is not flapping (0.00% state change).
[1307617373.199487] [016.1] [pid=377] Deleted check result file '/usr/local/nagios/var/spool/checkresults/creM40o'
I've already try increasing the cscript timeout ("cscript.exe //T XXX ..." in "NSC.ini") and the NRPE timout ("...check_nrpe -t XXX..." in "commands.cfg") but the problem remains.
Does anyone known what this could be happeining? I cant understand why Nagios Core report an "Unknown" state for my "Win Clock" service in host "MyServer" when my script never return me and exit status of "3".
Please tell me if more information (like the "commands.cfg" or something else) is needed to help me solve this issue.
Thanks in advance!
PD: Sorry for my poor English.
