Hi
Is there a way to configure Nagios XI URL using a FQDN rather than an Ip Address ?
Nagios URL
Re: Nagios URL
Yes. Set it in admin --> manage system config --> program url.
Re: Nagios URL
Tried changing it there, but after submitting the change i can only access to URL via the Ip address.
Re: Nagios URL
Does it time out? Can you ping the XI server with the fqdn?
Re: Nagios URL
Pings ok, when you try and browse its an instant error. Page cannot be loaded.
Re: Nagios URL
Run the following from a terminal on your workstation (xterm/cmd):
Post the output.
nslookup <fqdn of nagios server>Former Nagios employee
Re: Nagios URL
Issue resolved..
My issue is with my proxy server, turn it off and everything works perfectly.
Thank you for your help
