System Info
Linux Distribution and version?
*Linux version 2.6.18-348.16.1.el5PAE #1 SMP Wed Aug 21 04:49:45 EDT 2013 i686 i686 i386 GNU/Linux
CentOS release 5.7 (Final)
32 or 64bit?
32 bit
VMware Image or Manual Install of XI?
VMware Image
Are there specials configurations on your system, ie; is Gnome installed? Are you using a proxy? Are you using SSL?
Forced SSL on NagiosXi login web screen
Nagios Xi version: Nagios XI 2012R2.4
Issue:
How can I monitor memory usage on linux servers, but without the buffers and cache?
check_mem but without buffers and cache
Re: check_mem but without buffers and cache
Lets first see if the plugin you are using will allow you to do this, please link to the download page of this plugin, or upload it here, there are many check_mem plugins out there.
It's the one that comes with NagiosXi.
Did you install the NRPE package, or xi agent package on the remote host? Can you share the commands section of your nrpe.cfg file from that system please?
