Goodmorning,
I recently browsed the entire internet to find a good manual for check_ssh
I really don't know why the command doesn't work.
The host has of course been created.
What I am doing is in Objects.cfg:
define services{
use Generic-service
hostname PRDITSWEL01
service_description ssh monitoring
check_command check_ssh
COMMANDS.CFG
# 'check_ssh' command definition
command_name check_ssh
command_line $USER1$/check_ssh $ARG1$ $HOSTADDRESS$
The Error I receive is:
NRPE: Command 'check_ssh' not defined.
I must say that I also tried to use the following as check_command: check_nrpe!check_ssh
so it could be an old output???
I am really stuck in this one.
I must admit that I didn't do anything on the remote host ( from which I want to know if the port is open ) and the port is closed ( but then I assume that I should received a message that the port is closed or some sort ).
Your help would be gratefully appreciated.
check_ssh unsolved
Re: check_ssh unsolved
check_ssh can be run from the nagios server as it is just checking a remote, public port. You do not use check_ssh through nrpe (unless you are using nrpe to access a check proxy/firewalled node/etc).
(replace <hostname> with the fqdn/ip of the host PRDITSWEL01)
I would agree. Can you try running check_ssh from the cli?dre2007 wrote:I must say that I also tried to use the following as check_command: check_nrpe!check_ssh
/usr/local/nagios/libexec/check_ssh <hostname>Former Nagios employee
Thanks that worked. Also opened the port so everything works now.
Thanks for letting us know!
