excluding alert for specific condition
vinothsethuram
I'm using check_http plugin to monitor my apis. I want to stop sending alert/recovery emails for specific known failure. If I get cookie_error string in response I do not want to send warning/recovery emails. Please help
Re: excluding alert for specific condition
You may need to create a wrapper script to check the status output of check_http and not alert on the cookie error.
vinothsethuram
Alert conditions would have specified in check_http. Then how come we modify alert condition by writing wrapper class without editing check_http?
Because writing a wrapper is a lot faster and easier, frankly. check_http is written in C, whereas a wrapper can be in whatever language you are comfortable in. Also if you modify check_http then an other check that uses it also has that modification. This may or may not cause an issue, but it is still a good idea to keep the core plugins as they are.
Can you give me an example of the command and the status response from the cli? You may have to use a wrapper as you need to alter the return status code based on the content of the returned status string.
vinothsethuram
Request
check_http -H xyz.abcd.com -u 'https://xyz.abcd.com?param=1¶m2=3' -T 'application/json' -v
Response
STATUS: HTTP/1.1 401 Unauthorized
**** HEADER ****
Content-Language: en-US
Content-Type: application/xml
Date: Fri, 10 Jan 2014 18:44:42 GMT
Content-Length: 239
Connection: Close
**** CONTENT ****
"errors": [
"errorCode": "12345",
"errorKey": "INVALID_COOKIE",
"errorMessage": "12345: An invalid cookie occured"
"errorParameters": ""
Response
**** HEADER ****
Content-Length: 239
Connection: Close
**** CONTENT ****
"errors": [
So yea, in this case you simply write a script to call check_http with those parameters, grep the output for the string, and modify the exit code appropriately.
sreinhardt
- -fno-stack-protector
Just an example, not something you should put in production, however a script to wrap this could look like:
#!/bin/bash
result=$(check_http -H xyz.abcd.com -u 'https://xyz.abcd.com?param=1¶m2=3' -T 'application/json' -v)
if [[ $(echo $result | grep -i "401 Unauthorized") ]] && [[ $(echo $result | grep -i "12345: An invalid cookie occured") ]]; then
echo "OK - Known error 12345 was recieved."
exit 0
else
echo "$result"
exit $?
fi
