Server performance
ancovington
Server performance
Post by ancovington »
I noticed that there was a performance issue once I added the VM guest OS to each individual host so I added more memory to the Nagios server. Why is it that the server is still running slow and errors are being generated for the Data Stores of the Vcenter server that was resolved before. Here is a screen shot.
abrist
Red Shirt
Re: Server performance
Post by abrist »
Memory was most likely not the bottleneck, CPU is. What is the output of:
ps -aux
top -n1 | grep load
lscpu
Do you have some sort of additional firewall, tcpwrappers or xinetd rule that is causing the connection to drop? Can you post the output of "top" in code wraps?
ancovington
[root@nagios ~]# ps -aux
nagios   20991  0.0  0.0      0     0 ?        Z    08:21   0:01 [che] <defunct>
nagios   21100  0.0  0.0  35320   448 ?        S    08:21   0:00 /usr/local/nagi
nagios   21101  0.0  0.0  35320   448 ?        S    08:21   0:00 /usr/local/nagi
nagios   21115  0.0  0.0      0     0 ?        Z    08:21   0:00 [che] <defunct>
nagios   21116  0.0  0.0      0     0 ?        Z    08:21   0:00 [che] <defunct>
nagios   21129  0.0  0.0  35320   448 ?        S    08:21   0:00 /usr/local/nagi
nagios   21136  0.0  0.0      0     0 ?        Z    08:21   0:01 [che] <defunct>
root     23782  0.1  0.0  98156  4124 ?        Ss   08:56   0:00 sshd: root@nott
root     23791  0.0  0.0  55492  2228 ?        Ss   08:56   0:00 /usr/libexec/op
root     23800  0.0  0.0  98156  4112 ?        Ss   08:56   0:00 sshd: root@pts/
root     23802  0.0  0.0 108304  1900 pts/0    Ss   08:56   0:00 -bash
root     23868  0.0  0.0 140096  1352 ?        S    08:57   0:00 CROND
nagios   23876  0.0  0.0   9196  1184 ?        Ss   08:57   0:00 /bin/sh -c /usr
nagios   23879  0.1  0.2 222424 22452 ?        S    08:57   0:00 /usr/bin/php -q
postgres 24007  0.0  0.0 215408  4916 ?        Ss   08:57   0:00 postgres: nagio
nagios   24505  0.0  0.0  35324  5012 ?        S    08:57   0:00 /usr/local/nagi
nagios   24507  3.2  0.5 223288 47996 ?        R    08:57   0:01 Hiding the comm
nagios   24558  0.0  0.0  35324  5012 ?        S    08:57   0:00 /usr/local/nagi
nagios   24563  0.0  0.0  35324  5012 ?        S    08:57   0:00 /usr/local/nagi
nagios   24569  0.0  0.0  35324  5012 ?        S    08:57   0:00 /usr/local/nagi
nagios   24571  0.0  0.0  35324  5012 ?        S    08:57   0:00 /usr/local/nagi
nagios   24574  0.0  0.0  35324  5012 ?        S    08:57   0:00 /usr/local/nagi
nagios   24580  2.1  0.4 206796 36504 ?        S    08:57   0:00 /usr/bin/perl -
nagios   24583  2.1  0.4 206796 36512 ?        S    08:57   0:00 /usr/bin/perl -
nagios   24585  2.2  0.4 206796 36504 ?        S    08:57   0:00 /usr/bin/perl -
nagios   24586  2.1  0.4 206796 36508 ?        S    08:57   0:00 /usr/bin/perl -
nagios   24588  2.2  0.4 206796 36508 ?        S    08:57   0:00 /usr/bin/perl -
nagios   24594  0.0  0.0  35324  5012 ?        S    08:57   0:00 /usr/local/nagi
nagios   24595  0.0  0.0  35324  5012 ?        S    08:57   0:00 /usr/local/nagi
nagios   24602  0.0  0.0  35324  5012 ?        S    08:57   0:00 /usr/local/nagi
nagios   24605  2.1  0.4 206796 36512 ?        S    08:57   0:00 /usr/bin/perl -
nagios   24606  2.2  0.4 206796 36508 ?        S    08:57   0:00 /usr/bin/perl -
nagios   24611  2.1  0.4 206796 36508 ?        S    08:57   0:00 /usr/bin/perl -
nagios   24612  0.0  0.0  35324  5012 ?        S    08:57   0:00 /usr/local/nagi
nagios   24613  2.2  0.4 206796 36512 ?        S    08:57   0:00 /usr/bin/perl -
nagios   24691  0.0  0.0  35324  5012 ?        S    08:57   0:00 /usr/local/nagi
nagios   24695  2.3  0.4 206796 36504 ?        S    08:57   0:00 /usr/bin/perl -
nagios   24740  0.0  0.0  35324  5012 ?        S    08:57   0:00 /usr/local/nagi
nagios   24743  2.9  0.4 207484 37256 ?        R    08:57   0:00 /usr/bin/perl -
apache   24768  2.8  0.1 177724 13900 ?        R    08:57   0:00 /usr/bin/rrdtoo
nagios   24852  0.0  0.0  35324  5004 ?        S    08:57   0:00 /usr/local/nagi
nagios   24859  3.3  0.4 206368 36136 ?        R    08:57   0:00 /usr/bin/perl -
nagios   24863  0.0  0.0  35324  5004 ?        S    08:57   0:00 /usr/local/nagi
nagios   24864  0.0  0.0  35324  5004 ?        S    08:57   0:00 /usr/local/nagi
nagios   24865  0.0  0.0  35324  5004 ?        S    08:57   0:00 /usr/local/nagi
nagios   24866  0.0  0.0  35324  5004 ?        S    08:57   0:00 /usr/local/nagi
nagios   24867  0.0  0.0  35324  5004 ?        S    08:57   0:00 /usr/local/nagi
nagios   24868  3.4  0.4 206500 36224 ?        R    08:57   0:00 /usr/bin/perl -
nagios   24869  3.4  0.4 205100 34760 ?        R    08:57   0:00 /usr/bin/perl -
nagios   24870  3.3  0.4 205100 34764 ?        R    08:57   0:00 /usr/bin/perl -
nagios   24871  3.2  0.4 206892 36552 ?        R    08:57   0:00 /usr/bin/perl -
nagios   24872  3.4  0.4 205100 34764 ?        R    08:57   0:00 /usr/bin/perl -
nagios   24901  0.0  0.0  35324  5004 ?        S    08:57   0:00 /usr/local/nagi
nagios   24902  0.0  0.0  35324  5004 ?        S    08:57   0:00 /usr/local/nagi
nagios   24903  0.0  0.0  35324  5004 ?        S    08:57   0:00 /usr/local/nagi
nagios   24904  0.0  0.0  35324  5004 ?        S    08:57   0:00 /usr/local/nagi
nagios   24905  0.0  0.0  35324  5004 ?        S    08:57   0:00 /usr/local/nagi
nagios   24906  0.0  0.0  35324  5004 ?        S    08:57   0:00 /usr/local/nagi
nagios   24907  0.0  0.0  35324  5004 ?        S    08:57   0:00 /usr/local/nagi
nagios   24908  0.0  0.0  35324  5004 ?        S    08:57   0:00 /usr/local/nagi
nagios   24912  3.3  0.4 206148 35852 ?        R    08:57   0:00 /usr/bin/perl -
nagios   24918  3.6  0.4 206280 35948 ?        R    08:57   0:00 /usr/bin/perl -
nagios   24923  3.4  0.4 206148 35900 ?        R    08:57   0:00 /usr/bin/perl -
nagios   24931  3.3  0.4 206148 35828 ?        R    08:57   0:00 /usr/bin/perl -
nagios   24932  3.5  0.4 206280 35960 ?        R    08:57   0:00 /usr/bin/perl -
nagios   24933  3.6  0.4 206280 35968 ?        R    08:57   0:00 /usr/bin/perl -
nagios   24935  3.5  0.4 206148 35888 ?        R    08:57   0:00 /usr/bin/perl -
nagios   24936  0.0  0.0  35324  5004 ?        S    08:57   0:00 /usr/local/nagi
nagios   24937  0.0  0.0  35324  5004 ?        S    08:57   0:00 /usr/local/nagi
nagios   24938  0.0  0.0  35324  5004 ?        S    08:57   0:00 /usr/local/nagi
nagios   24939  0.0  0.0  35324  5004 ?        S    08:57   0:00 /usr/local/nagi
nagios   24940  0.0  0.0  35324  5004 ?        S    08:57   0:00 /usr/local/nagi
nagios   24941  0.0  0.0  35324  5004 ?        S    08:57   0:00 /usr/local/nagi
nagios   24942  0.0  0.0  35324  5004 ?        S    08:57   0:00 /usr/local/nagi
nagios   24943  0.0  0.0  35324  5004 ?        S    08:57   0:00 /usr/local/nagi
nagios   24944  0.0  0.0  35324  5004 ?        S    08:57   0:00 /usr/local/nagi
nagios   24945  0.0  0.0  35324  5004 ?        S    08:57   0:00 /usr/local/nagi
nagios   24946  0.0  0.0  35324  5004 ?        S    08:57   0:00 /usr/local/nagi
nagios   24947  0.0  0.0  35324  5004 ?        S    08:57   0:00 /usr/local/nagi
nagios   24948  3.3  0.4 206148 35828 ?        R    08:57   0:00 /usr/bin/perl -
nagios   24949  3.5  0.4 206148 35884 ?        R    08:57   0:00 /usr/bin/perl -
nagios   24950  2.2  0.4 203900 33552 ?        S    08:57   0:00 /usr/bin/perl -
nagios   24951  3.5  0.4 207212 36856 ?        R    08:57   0:00 /usr/bin/perl -
nagios   24952  2.6  0.4 205220 34928 ?        R    08:57   0:00 /usr/bin/perl -
nagios   24953  2.4  0.4 205220 34880 ?        S    08:57   0:00 /usr/bin/perl -
nagios   24954  2.4  0.4 205220 34884 ?        S    08:57   0:00 /usr/bin/perl -
nagios   24955  2.4  0.4 205092 34752 ?        R    08:57   0:00 /usr/bin/perl -
nagios   24956  2.6  0.4 205220 34880 ?        S    08:57   0:00 /usr/bin/perl -
nagios   24957  2.3  0.4 204032 33704 ?        S    08:57   0:00 /usr/bin/perl -
nagios   24958  2.3  0.4 204296 34020 ?        R    08:57   0:00 /usr/bin/perl -
nagios   24959  2.2  0.4 204032 33704 ?        S    08:57   0:00 /usr/bin/perl -
nagios   24960  2.3  0.4 204032 33696 ?        S    08:57   0:00 /usr/bin/perl -
nagios   24970  0.0  0.0  35324  5004 ?        S    08:57   0:00 /usr/local/nagi
nagios   24971  0.0  0.0  35324  5004 ?        S    08:57   0:00 /usr/local/nagi
nagios   24972  0.0  0.0  35324  5004 ?        S    08:57   0:00 /usr/local/nagi
nagios   24973  0.0  0.0  35324  5004 ?        S    08:57   0:00 /usr/local/nagi
nagios   24974  0.0  0.0  35324  5004 ?        S    08:57   0:00 /usr/local/nagi
nagios   24975  0.0  0.0  35324  5004 ?        S    08:57   0:00 /usr/local/nagi
nagios   24976  0.0  0.0  35324  5004 ?        S    08:57   0:00 /usr/local/nagi
nagios   24977  0.0  0.0  35324  5004 ?        S    08:57   0:00 /usr/local/nagi
nagios   24978  0.0  0.0  35324  5004 ?        S    08:57   0:00 /usr/local/nagi
nagios   24979  0.0  0.0  35324  5004 ?        S    08:57   0:00 /usr/local/nagi
nagios   24980  0.0  0.0  35324  5004 ?        S    08:57   0:00 /usr/local/nagi
nagios   24981  0.0  0.0  35324  5004 ?        S    08:57   0:00 /usr/local/nagi
nagios   24982  0.0  0.0  35324  5004 ?        S    08:57   0:00 /usr/local/nagi
nagios   24986  0.0  0.0  35324  5004 ?        S    08:57   0:00 /usr/local/nagi
nagios   24987  0.0  0.0  35324  5004 ?        S    08:57   0:00 /usr/local/nagi
nagios   24988  0.0  0.0  35324  5004 ?        S    08:57   0:00 /usr/local/nagi
nagios   24989  0.0  0.0  35324  5004 ?        S    08:57   0:00 /usr/local/nagi
nagios   24990  0.0  0.0  35324  5004 ?        S    08:57   0:00 /usr/local/nagi
nagios   24991  0.0  0.0  35324  5004 ?        S    08:57   0:00 /usr/local/nagi
nagios   24993  3.4  0.4 206148 35824 ?        R    08:57   0:00 /usr/bin/perl -
nagios   24994  3.4  0.4 206148 35844 ?        R    08:57   0:00 /usr/bin/perl -
nagios   24997  3.5  0.4 206148 35824 ?        R    08:57   0:00 /usr/bin/perl -
nagios   24999  3.2  0.4 206552 36264 ?        R    08:57   0:00 /usr/bin/perl -
nagios   25000  3.4  0.4 206148 35828 ?        R    08:57   0:00 /usr/bin/perl -
nagios   25001  3.2  0.4 206148 35828 ?        R    08:57   0:00 /usr/bin/perl -
nagios   25003  3.4  0.4 206148 35824 ?        R    08:57   0:00 /usr/bin/perl -
nagios   25004  3.3  0.4 206148 35828 ?        R    08:57   0:00 /usr/bin/perl -
nagios   25006  3.2  0.4 205832 35568 ?        R    08:57   0:00 /usr/bin/perl -
nagios   25007  3.5  0.4 206148 35888 ?        R    08:57   0:00 /usr/bin/perl -
nagios   25008  3.5  0.4 206148 35836 ?        R    08:57   0:00 /usr/bin/perl -
nagios   25009  3.2  0.4 206148 35840 ?        R    08:57   0:00 /usr/bin/perl -
nagios   25010  3.4  0.4 206148 35828 ?        R    08:57   0:00 /usr/bin/perl -
nagios   25011  3.5  0.4 207092 36860 ?        R    08:57   0:00 /usr/bin/perl -
nagios   25012  3.4  0.4 205096 34760 ?        R    08:57   0:00 /usr/bin/perl -
nagios   25013  2.4  0.4 205092 34740 ?        R    08:57   0:00 /usr/bin/perl -
nagios   25014  3.5  0.4 207224 36872 ?        R    08:57   0:00 /usr/bin/perl -
nagios   25015  2.4  0.4 204032 33696 ?        S    08:57   0:00 /usr/bin/perl -
nagios   25016  2.4  0.4 204032 33700 ?        S    08:57   0:00 /usr/bin/perl -
nagios   25017  0.0  0.0  35324  5004 ?        S    08:57   0:00 /usr/local/nagi
nagios   25018  0.0  0.0  35324  5004 ?        S    08:57   0:00 /usr/local/nagi
nagios   25019  0.0  0.0  35324  5004 ?        S    08:57   0:00 /usr/local/nagi
nagios   25020  0.0  0.0  35324  5004 ?        S    08:57   0:00 /usr/local/nagi
nagios   25021  0.0  0.0  35324  5004 ?        S    08:57   0:00 /usr/local/nagi
nagios   25022  0.0  0.0  35324  5004 ?        S    08:57   0:00 /usr/local/nagi
nagios   25023  2.4  0.4 204032 33700 ?        S    08:57   0:00 /usr/bin/perl -
nagios   25024  2.3  0.4 203900 33552 ?        S    08:57   0:00 /usr/bin/perl -
nagios   25025  2.4  0.4 203900 33552 ?        S    08:57   0:00 /usr/bin/perl -
nagios   25026  2.4  0.4 204032 33696 ?        S    08:57   0:00 /usr/bin/perl -
nagios   25027  2.4  0.4 204032 33700 ?        S    08:57   0:00 /usr/bin/perl -
nagios   25028  2.5  0.4 204032 33700 ?        S    08:57   0:00 /usr/bin/perl -
nagios   25032  0.0  0.0  35324  5004 ?        S    08:58   0:00 /usr/local/nagi
nagios   25033  0.0  0.0  35324  5004 ?        S    08:58   0:00 /usr/local/nagi
nagios   25034  0.0  0.0  35324  5004 ?        S    08:58   0:00 /usr/local/nagi
nagios   25035  0.0  0.0  35324  5004 ?        S    08:58   0:00 /usr/local/nagi
nagios   25036  0.0  0.0  35324  5004 ?        S    08:58   0:00 /usr/local/nagi
nagios   25037  0.0  0.0  35324  5004 ?        S    08:58   0:00 /usr/local/nagi
nagios   25038  0.0  0.0  35324  5004 ?        S    08:58   0:00 /usr/local/nagi
nagios   25039  0.0  0.0  35324  5004 ?        S    08:58   0:00 /usr/local/nagi
nagios   25040  0.0  0.0  35324  5004 ?        S    08:58   0:00 /usr/local/nagi
nagios   25041  0.0  0.0  35324  5004 ?        S    08:58   0:00 /usr/local/nagi
nagios   25042  0.0  0.0  35324  5004 ?        S    08:58   0:00 /usr/local/nagi
nagios   25043  0.0  0.0  35324  5004 ?        S    08:58   0:00 /usr/local/nagi
nagios   25045  3.6  0.4 206148 35840 ?        R    08:58   0:00 /usr/bin/perl -
nagios   25046  3.6  0.4 206148 35836 ?        R    08:58   0:00 /usr/bin/perl -
nagios   25047  3.5  0.4 206552 36248 ?        R    08:58   0:00 /usr/bin/perl -
nagios   25049  3.3  0.4 206896 36552 ?        R    08:58   0:00 /usr/bin/perl -
nagios   25050  3.1  0.4 205224 34900 ?        R    08:58   0:00 /usr/bin/perl -
nagios   25051  3.4  0.4 206148 35828 ?        R    08:58   0:00 /usr/bin/perl -
nagios   25052  3.1  0.4 205224 34912 ?        R    08:58   0:00 /usr/bin/perl -
nagios   25053  3.5  0.4 206148 35840 ?        R    08:58   0:00 /usr/bin/perl -
nagios   25054  3.5  0.4 206148 35840 ?        R    08:58   0:00 /usr/bin/perl -
nagios   25055  3.0  0.4 205224 34896 ?        R    08:58   0:00 /usr/bin/perl -
nagios   25056  3.0  0.4 205224 34896 ?        R    08:58   0:00 /usr/bin/perl -
nagios   25057  3.0  0.4 205224 34900 ?        R    08:58   0:00 /usr/bin/perl -
root     25065  0.0  0.0 140096  1352 ?        S    08:58   0:00 CROND
root     25066  0.0  0.0 140096  1352 ?        S    08:58   0:00 CROND
root     25067  0.0  0.0 140096  1352 ?        S    08:58   0:00 CROND
root     25068  0.0  0.0 140096  1352 ?        S    08:58   0:00 CROND
root     25069  0.0  0.0 140096  1352 ?        S    08:58   0:00 CROND
nagios   25070  0.0  0.0   9196  1184 ?        Ss   08:58   0:00 /bin/sh -c /usr
nagios   25071  0.0  0.0   9196  1188 ?        Ss   08:58   0:00 /bin/sh -c /usr
nagios   25072  0.0  0.0   9196  1184 ?        Ss   08:58   0:00 /bin/sh -c /usr
nagios   25073  0.0  0.0   9196  1188 ?        Ss   08:58   0:00 /bin/sh -c /usr
nagios   25074  0.0  0.0   9196  1188 ?        Ss   08:58   0:00 /bin/sh -c /usr
nagios   25078  0.8  0.2 222424 21716 ?        S    08:58   0:00 /usr/bin/php -q
nagios   25079  1.0  0.2 222184 22636 ?        S    08:58   0:00 /usr/bin/php -q
nagios   25080  1.3  0.3 229068 29008 ?        S    08:58   0:00 /usr/bin/php -q
nagios   25082  0.8  0.2 222324 22308 ?        S    08:58   0:00 /usr/bin/php -q
nagios   25084  0.9  0.2 222812 22368 ?        S    08:58   0:00 /usr/bin/php -q
postgres 25086  0.0  0.0 215408  4884 ?        Ss   08:58   0:00 postgres: nagio
postgres 25088  0.0  0.0 215408  4900 ?        Ss   08:58   0:00 postgres: nagio
postgres 25099  0.2  0.0 215472  5252 ?        Ss   08:58   0:00 postgres: nagio
postgres 25105  0.5  0.0 215428  6724 ?        Ss   08:58   0:00 postgres: nagio
nagios   25162  0.0  0.0   9196  1192 ?        S    08:58   0:00 sh -c /usr/bin/
nagios   25163  0.0  0.0   4108   792 ?        S    08:58   0:00 /usr/bin/iostat
nagios   25164  0.0  0.0   4100   548 ?        S    08:58   0:00 tail --lines=2
nagios   25165  0.0  0.0   4080   520 ?        S    08:58   0:00 head --lines=1
nagios   25166  0.0  0.0   9080   836 ?        S    08:58   0:00 awk { print $1,
nagios   25168  0.0  0.0  35324  5008 ?        S    08:58   0:00 /usr/local/nagi
nagios   25169  0.0  0.0  35324  5008 ?        S    08:58   0:00 /usr/local/nagi
nagios   25170  0.0  0.0  35324  5008 ?        S    08:58   0:00 /usr/local/nagi
nagios   25171  0.0  0.0  35324  5008 ?        S    08:58   0:00 /usr/local/nagi
nagios   25172  0.0  0.0  35324  5008 ?        S    08:58   0:00 /usr/local/nagi
nagios   25173  0.0  0.0  35324  5008 ?        S    08:58   0:00 /usr/local/nagi
nagios   25174  0.0  0.0  35324  5008 ?        S    08:58   0:00 /usr/local/nagi
nagios   25175  0.0  0.0  35324  5008 ?        S    08:58   0:00 /usr/local/nagi
nagios   25176  0.0  0.0  35324  5008 ?        S    08:58   0:00 /usr/local/nagi
nagios   25177  0.0  0.0  35324  5008 ?        S    08:58   0:00 /usr/local/nagi
nagios   25178  0.0  0.0  35324  5008 ?        S    08:58   0:00 /usr/local/nagi
nagios   25179  0.0  0.0  35324  5008 ?        S    08:58   0:00 /usr/local/nagi
nagios   25180  0.0  0.0  35324  5008 ?        S    08:58   0:00 /usr/local/nagi
nagios   25181  0.0  0.0  35324  5008 ?        S    08:58   0:00 /usr/local/nagi
nagios   25182  4.0  0.0 126252  4276 ?        R    08:58   0:00 /usr/bin/perl -
nagios   25184  4.0  0.0 126780  4748 ?        R    08:58   0:00 /usr/bin/perl -
nagios   25185  4.0  0.0 126252  4280 ?        R    08:58   0:00 /usr/bin/perl -
nagios   25186  4.0  0.0 126384  4348 ?        R    08:58   0:00 /usr/bin/perl -
nagios   25187  4.0  0.0 126384  4428 ?        R    08:58   0:00 /usr/bin/perl -
nagios   25188  4.0  0.0 126516  4548 ?        R    08:58   0:00 /usr/bin/perl -
nagios   25189  4.0  0.0 126516  4488 ?        R    08:58   0:00 /usr/bin/perl -
nagios   25190  4.0  0.0 126648  4680 ?        R    08:58   0:00 /usr/bin/perl -
nagios   25191  4.0  0.0 126384  4336 ?        R    08:58   0:00 /usr/bin/perl -
nagios   25192  4.0  0.0 125564  3444 ?        R    08:58   0:00 /usr/bin/perl -
nagios   25193  4.0  0.0 126648  4620 ?        R    08:58   0:00 /usr/bin/perl -
nagios   25194  4.0  0.0 126252  4276 ?        R    08:58   0:00 /usr/bin/perl -
nagios   25195  0.0  0.0  35324  5008 ?        S    08:58   0:00 /usr/local/nagi
nagios   25196  0.0  0.0  35324  5008 ?        S    08:58   0:00 /usr/local/nagi
nagios   25197  4.0  0.0 126252  4276 ?        R    08:58   0:00 /usr/bin/perl -
nagios   25198  4.0  0.0 126252  4276 ?        R    08:58   0:00 /usr/bin/perl -
nagios   25199  3.0  0.0 126648  4620 ?        R    08:58   0:00 /usr/bin/perl -
nagios   25200  4.0  0.0 126092  3980 ?        R    08:58   0:00 /usr/bin/perl -
root     25201  3.0  0.0 110232  1196 pts/0    R+   08:58   0:00 ps -aux
[root@nagios ~]# top -n1 | grep load
top - 09:00:41 up 50 min,  2 users,  load average: 123.11, 78.62, 72.50
[root@nagios ~]# lscpu
Architecture:          x86_64
CPU op-mode(s):        32-bit, 64-bit
Byte Order:            Little Endian
CPU(s):                4
On-line CPU(s) list:   0-3
Thread(s) per core:    1
Core(s) per socket:    1
Socket(s):             4
NUMA node(s):          1
Vendor ID:             GenuineIntel
CPU family:            6
Model:                 26
Stepping:              4
CPU MHz:               2260.961
BogoMIPS:              4521.92
Hypervisor vendor:     VMware
Virtualization type:   full
L1d cache:             32K
L1i cache:             32K
L2 cache:              256K
L3 cache:              24576K
NUMA node0 CPU(s):     0-3
abrist
Red Shirt
Post by abrist »
Most of the output from the ps is truncated. Can you redirect the output to a file and post the file?
ps -aux > /tmp/ps.txt
Attach /tmp/ps.txt to your next post.
ancovington
Here it is
abrist
Red Shirt
Post by abrist »
That is an awful lot of esx checks. How many checks are you doing every 1 and 5 minutes? What is the interval on the esx checks?
ancovington
The Check interval is 5 min
Retry interval is 1 min and
Max check attempts is 5.
abrist
Red Shirt
Post by abrist »
abrist wrote:How many checks are you doing every 1 and 5 minutes?
ancovington
How do I find out that info?
