New installation issue, httpd service wont start. Help!
ctmiller82
Post by ctmiller82 »
Hello I have a fresh install of the newest nagios xi running inside vsphere
Virtual Machine version is 7
CentOS release 5.4 (final)
Kernel 2.6.18-238.12.1.e15 on an 1686
After configuring my interface and brining it up I noticed I was unable to access the the nagiosxi configuration page on port 80. After some basic troubleshooting I discovered the following problem when running servce httpd start
Starting httpd: (2)No such file or directory: httpd: could not open error log file /etc/httpd/logs/error_log.
Unable to open logs [failed]
I thought maybe something went wrong during installation so I preformed another install and the same problem is happening. I'm not that familiar with Linux/Unix OS's so my ability is weak but I attempted to open /etc/httpd/logs/error_log
When i open /etc/httpd/logs/ it tells me there is no directory "logs"
Next I decided to do a ls -l logs inside the /etc/httpd/ directory, below is my output
lrwxrwxrwx 1 root root 19 May 24 14:49 logs -> ../../var/log/httpd
Any help would be much appreciated, thank you!
mguthrie
Re: New installation issue, httpd service wont start. Help!
Post by mguthrie »
Just to clarify, are you using our pre-installed Nagios XI VM, or did you do a manual install on your own VM?
Do you have Gnome installed on this system?
ctmiller82
I am using the prebuilt vmware appliance.
ctmiller82
I am running the pre configured VM that I converted to run inside VSphere using the VMWare stand alone converter.
tonyyarusso
Post by tonyyarusso »
What date did you download the VM? What is the md5sum of the ZIP file you downloaded?
Tony Yarusso
Technical Services
___
TIES
Web: http://ties.k12.mn.us/
ctmiller82
Not sure how to calculate the md5 hash but I downloaded on Saturday 6/11/2011 and it appears to be the newest release. Any idea on whats wrong?
ctmiller82
Small Update
I re downloaded the current VMWare Image, reinstalled, same thing. I than changed the VM Version from 7 to 4 and re converted, same thing. Possible the image is bad? Any directions on how to fix?
tonyyarusso
Yup, confirmed that our image is broken. Here's what you need to do for a temporary workaround:
sed -i '/.*MACADDR.*/d' /etc/sysconfig/network-scripts/ifcfg-eth0
mkdir /var/log/httpd
chown apache.apache /var/log/httpd
Then reboot.
Tony Yarusso
Technical Services
___
TIES
